Old 05-18-2013, 02:16 PM   #1
SERVED_USMC
SERVED_USMC's Avatar
Drives: Slow
Can someone check out the fitment of my F14's for me.
I got these a couple weeks ago and just had the chance to throw one of them on the back to check everything out before I ordered tires.
The rim looks like a tight fit on the back side enough so that I think Im going to have rubbing issues.
My only other concern is that width of the wheel. I ordered a 20x11, which is what the box says, but the face to face measurement is 12". Im not to concerend about that though, because I dont know the exact way to measure width. Just looking for someone to chime in and let me know what they think.
SERVED_USMC is offline   Reply With Quote
Old 05-18-2013, 02:20 PM   #2
turboguy327
Banned
Drives: 2011 Chevy Camaro
You measure a wheel by where the tire bead hits. You added a extra half inch on either side.
turboguy327 is offline   Reply With Quote
Old 05-18-2013, 02:23 PM   #3
SERVED_USMC
Drives: Slow
I assumed as much, thats why I wasnt concerned about it.
Any opinion on the room from the back of the rim to the car?
Old 05-18-2013, 02:23 PM   #4
SERVED_USMC
Drives: Slow
The rim is fine now the way it sits, but I dont know what its gonna look like with a 315/35 on there.
Old 05-18-2013, 02:49 PM   #5
TBone
Negative Camber Junkie
TBone's Avatar
Drives: 2010 1SS LS3/6MN ABM 1 of 23
What brand of tire are you going to run?
T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same.
Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different.
I can't wait for my next
Track fix.
DA HAWKS OWN DA CUP!!!!!
TBone is offline   Reply With Quote
Old 05-18-2013, 04:18 PM   #6
SERVED_USMC
Drives: Slow
Nitto NT05R's for the rear in 315/35
Old 05-18-2013, 06:44 PM   #7
UF4LIFE102SS
Treasure Coast Camaro 5
UF4LIFE102SS's Avatar
Drives: 2010 2 SS
Heres a 315
Old 05-18-2013, 11:34 PM   #8
Denis
Denis's Avatar
Drives: 2010 SS
Damn 11" wide? Fatty tires back there!
Old 05-19-2013, 10:13 AM   #9
Warhead
Warhead's Avatar
Drives: 2010 Black 2SS/RS
With that offset you may have some rubbing issue's, maybe with E-brake cable as well as wheel well. I have 315/35 Nitto Invo's mounted on 20x10.5 with +42 offset. They sit perfect with no rubbing.
Warhead is offline   Reply With Quote
Old 05-19-2013, 11:05 AM   #10
SERVED_USMC
Drives: Slow
E brake cable looks like it could be a rub spot as well. I need to call one of the wheel vendors here and see what they think.
Old 05-19-2013, 03:41 PM   #11
SERVED_USMC
Drives: Slow
Anyone else care to chime in?
Old 05-19-2013, 04:21 PM   #12
blake2010ss
blake2010ss's Avatar
Drives: 2010 Camaro 2ss/rs
Send a message via AIM to blake2010ss Send a message via MSN to blake2010ss
my ebrake cable rubbed... i zip tied it up away from the wheel. I have a 305 nitto nt555r and not a single rub outside of the ebrake cable. The same people i ordered my wheels from have had customers run 315's on the same wheel size/offset.... no rub issue. I think you will be fine.
2010 Camaro 2SS/RS LS3
1093/1066
416, AGP 6262, E85, Cam
blake2010ss is offline   Reply With Quote
Old 05-19-2013, 04:32 PM   #13
SERVED_USMC
Drives: Slow
Awesome. Thanks for the help! I'll throw the tires on and put them on and see what happens. Hopefully, relocating the E brake bracket will be the extent of it.
Old 05-19-2013, 04:34 PM   #14
blake2010ss
Originally Posted by SERVED_USMC View Post
Awesome. Thanks for the help! I throw the tires on and out them on and see what happens. Hopefully, relocating the E brake will be the most modification I would have to make.
i just pulled the cable out of the seat it was in and zip tied it around the rear arm... i did 3 ties per side. you cant see it unless you really get down there and look.
1093/1066
