Old 05-19-2013, 03:00 PM   #1
fourmz
Fourmz
fourmz's Avatar
Drives: 2010 2SS/RS 1968 Firebird 1994 Z28
Fuel pressure gauge on maggie fuel rail
I need to replace the valve stem on the fuel block with my fuel pressure sensor. My question is, is there any trick to removing the valve stem? I tried to wrench it off and it wont budge. I cant put the torch to it. Do i have to remove the fuel block first?
Black-in-Black/Blue out 2010 2SS/RS LS-3 -Magnacharger TVS2300,OD cog belt drive, 3.4" pulley, Janetty smooth idle blower cam,ID-850 injectors,ZL1 fuel pump,MSD boost a pump, ADM FPCM Janetty custom tune,Doug Thorley long tube headers, Corsa catback,C.A.I. Intake, Roto-Fab Big Gulp Scoop, Monster LT1/SC Clutch assembly,Eibach pro kit plus, BMR cradle/diff bushings, Barton Shifter,JRE 3.91 Eaton Tru-Trac rear diff,Barton Short Throw SHifter, Boss 339 20" wheels,Painted heritage grille, Sparks Restoration Inverted blue/black SS emblems, Seibon BB carbon fiber hood, ZL1 front bumper conversion.
fourmz is offline   Reply With Quote
Old 05-20-2013, 03:30 PM   #2
Jessika
Drives: Anything Blown
If you are taking the Schrader valve out, you need the little tool to twist it out. It is the same tool a tire store would use for removing regular tire valve stems.
It will come out easy as pie with that tool.
Jessika is offline   Reply With Quote
Old 05-20-2013, 04:17 PM   #3
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
why not read fuel pressure through the obd2 port?
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
BigMatt is offline   Reply With Quote
Old 05-20-2013, 06:14 PM   #4
fourmz
Fourmz
fourmz's Avatar
I want to know exactly what I am getting at the rail.
Old 05-20-2013, 06:18 PM   #5
fourmz
Fourmz
fourmz's Avatar
Actually I was referring to the 1/8" NPT valve stem assembly that is screwed into the fuel block. I need to remove it so I can install my fuel pressure sensor.
Old 05-20-2013, 08:57 PM   #6
Jessika
Post a picture? I'm 90 percent sure that's the Schrader valve
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
Old 05-20-2013, 09:54 PM   #7
Kronix
NJ/SoCal HT5 COTW 3/25/12
Kronix's Avatar
Drives: 2015 Z06/14 C7/08 Z06/07 Tahoe Z71
Sounds like it
Built by Late Model Racecraft
Fastest C7 in Tri-State 10.13 @ 134mph
7/26/14 Corvette Challenge Raceway Park, E-Town, NJ
Kronix is offline   Reply With Quote
Old 05-20-2013, 11:48 PM   #8
fourmz
Fourmz
fourmz's Avatar
You are right it is the schrader valve. I took he fuel block off and am having a machine shop drill and tap a new hole so I can keep both.
Old 05-21-2013, 12:17 AM   #9
Jessika
Might be best to just use a Tee fitting off that port if you want both.
Old 05-21-2013, 01:45 PM   #10
fourmz
Fourmz
fourmz's Avatar
I just purchased the fitting, thanks for the advice Jessika.
Old 05-21-2013, 02:01 PM   #11
Jessika
You are very welcome. Glad I could help :-)
