Old 05-20-2013, 06:43 AM   #1
jrisebo
jrisebo's Avatar
Drives: 2011 Camaro RS "Bumble C"
V6 on 87 octane
This weekend I did a 500 mile round trip drive. Decided to try 87 octane (it was 40 cents cheaper at the station I was at). Well, After pretty much always using 93 octane, I can honestly say that using 87 octane DOES effect the perfomance of my car. It just seemed to run a bit rough, and certainly lacked a bit of pep when passing on highway speeds. Perhaps its a placebo effect since its my car, but im going back to 93 octane.
jrisebo is offline   Reply With Quote
Old 05-20-2013, 06:46 AM   #2
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
it's a known fact that running 87 on the 5th gen v6 Camaro makes the car pull timing. If you can feel it, is another matter, but it does affect performance.
Old 05-20-2013, 07:33 AM   #3
jd10013
Drives: 2012 camaro
I always put 93 in mine. usually fill up between 3/4 and 1/2 tank, so the extra 2-4 bucks a week isn't that big a deal to me.
jd10013 is offline   Reply With Quote
Old 05-20-2013, 07:48 AM   #4
Mvp_Me
I Use Three Pedals
Mvp_Me's Avatar
Drives: 2011 VR M6
I always use 91, would it be that much of a difference with this motor if I used 93? I always used 93 on my turbo car but this car I didn't think it mattered that much. If you guys see better mpg and performance then ill have to open my wallet a little wider I guess.
Mvp_Me is offline   Reply With Quote
Old 05-20-2013, 08:06 AM   #5
jrisebo
jrisebo's Avatar
Not sure about the MPG, just seems to run a bit smoother. That was my test, always going to use 93 now.
Old 05-20-2013, 08:10 AM   #6
SC2150
MPG overall should be better w/93 as well since the ECU is allowing the engine to run at optimine timing advance.
These engines are 11.3:1 compression ratio and even though marketing emphasizes 87 and cheap oil is reccomended, it is definately NOT best for the engine.
Old 05-20-2013, 08:16 AM   #7
Jonster
Jonster's Avatar
Drives: 18 2SS Vert Hotwheels
I was under the impression that the higher octanes only make a difference if you are really driving the car hard. (and also helps lengthen engine lifespan)
edit: Obviously putting 91 in SS/ZL1 minimum and 87 in LS/LT minimum
There are also many other factors when fueling up like brand and region. There are some articles on Shell V-power vs BP ultimate, but gas is different based upon region as well.
(Not sure if this helps, just spitting out some knowledge)
2018 2SS hot wheels convertible
Jonster is offline   Reply With Quote
Old 05-20-2013, 08:16 AM   #8
Mvp_Me
I Use Three Pedals
Mvp_Me's Avatar
Drives: 2011 VR M6
Ok good info, I always want to do what I can to keep my car running healthy. Ill run the tank down to E and fill her up with good ole 93.
Old 05-20-2013, 08:19 AM   #9
Mvp_Me
I Use Three Pedals
Mvp_Me's Avatar
Drives: 2011 VR M6
Also what about the people that can only get 91? Mid grade couldn't be that bad.
Old 05-20-2013, 08:25 AM   #10
Jonster
Jonster's Avatar
It depends. Some articles proved that some high tier 91 brands are just as good as low tier 93 brands.
Old 05-20-2013, 08:34 AM   #11
SPARTAN sui
PC Technician
SPARTAN sui's Avatar
Drives: 2016 Hyper Blue 2SS
I actually might switch over to premium grade because it's always seems to be $0.10 cheaper than regular. Which isn't saying much when it's $4.40 versus $4.50 :(
SPARTAN sui is offline   Reply With Quote
Old 05-20-2013, 08:39 AM   #12
Blue Demon
Blue Demon's Avatar
Drives: 2006 Corvette
Premium cheaper than regular? Sounds fishy.
Blue Demon is offline   Reply With Quote
Old 05-20-2013, 08:41 AM   #13
911medic
911medic's Avatar
Drives: 2012 SIM 2LT/1970 Camaro
Premium is cheaper than regular where you live?
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller
RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting
Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting
911medic is offline   Reply With Quote
Old 05-20-2013, 08:46 AM   #14
SPARTAN sui
PC Technician
Eh, it might be 89 only, which is "premium" for my small town. I'd have to look. But it's been that way for the past few years at least. Off and on, but typically is cheaper than regular 87.
This map is off a bit, we're definitely in the dark red category.
http://gasbuddy.com/gb_gastemperaturemap.aspx
http://www.usatoday.com/story/money/...igher/2166845/
