Old 05-21-2013, 09:46 PM   #1
camaro805
camaro805's Avatar
Drives: 2012 Black
Rear suspension removal
I'm trying to install my springs but I can't
Remove the back suspension.
I've taken the 4 screws above it and
2 screws below it.
I followed all the DIY and I can't get it
Any tips or videos you guys have
Thanks
camaro805 is offline   Reply With Quote
Old 05-21-2013, 09:49 PM   #2
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
CHMSC is offline   Reply With Quote
Old 05-21-2013, 10:49 PM   #3
RJT Impala
Stovebolt BluFlame 6
RJT Impala's Avatar
Drives: '12 2LT/RS, IBM; '20 Traverse Prem
Didn't realize how straight-up simple it was to swap the springs. Last time I did it was on an '83 GTI, and it required a spring compressor in order to disassemble the struts. Much more preload than what I saw in this video!
RJT Impala is offline   Reply With Quote
Old 05-21-2013, 11:33 PM   #4
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
If you are putting on lowering springs no spring compressor is needed, just be careful when disassembling. You will need a spring compressor if you are putting stock height springs back on though.
Most of the spring compression is done by the weight of the car on the spring it's self.
