Old 05-23-2013, 10:22 PM   #1
Bomber
Byron4
Bomber's Avatar
Drives: SS RJT
DIY removing the cloth from door panels?
Does anyboby remember the link to the DIY for removing the cloth on the 1SS door panels to prepare them for paint?
Bomber is offline   Reply With Quote
Old 05-27-2013, 10:24 PM   #2
Witchdoctor92
Witchdoctor92's Avatar
Drives: 2012 1SS Black with white rally str
Don't remember where it is, but I did the dash trim and all I did was pull out the staples and pull the cloth off. I then removed the residual adhesive from the plastic with mineral spirits and sprayed it with duplicolor color and clear.
It's good to be the King.
Witchdoctor92 is offline   Reply With Quote
Old 05-28-2013, 11:47 PM   #3
preppykid
preppykid's Avatar
Drives: Black LT Camaro
To add to what was previously stated, after the mineral spirits I used fine grit size to get rid of all the glue, then used primer, paint, and a clear coat.
preppykid is offline   Reply With Quote
Old 05-28-2013, 11:54 PM   #4
Q'smuscle
I was looking for the DIY thread too
Old 05-31-2013, 11:30 AM   #5
thisizpeter
thisizpeter's Avatar
Drives: 2012 Camaro
http://www.camaro5.com/forums/showth...+panel+removal
http://www.camaro5.com/forums/showpo...6&postcount=19
thisizpeter is offline   Reply With Quote
Old 05-31-2013, 11:32 AM   #6
thisizpeter
Drives: 2012 Camaro
Found em now I need the parts to do it!!!!! Can't wait
Old 03-31-2015, 08:50 PM   #7
Poogie Bear
Drives: 2012 Camaro white & blacked out
I did it, and it was very simple. Pry the panel off, remove staples, cleaned the glue and residue with GOOF OFF, one coat of primer and 2 coats of paint.
Poogie Bear is offline   Reply With Quote
