Old 06-28-2009, 11:46 AM   #1
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
2010 tire question/GM warranty
Looking to downsize to 18" rims(for an LT model) and the tires recommended are 245/55/18. Not a lot of selection(and a little too much rubber showing). What do you guys/gals think about dropping to a 245/45/18? Will it drop the stance noticeably? Will it void GM's warranty? And is 245/40/18 too close to the road to be worthwhile? Just looking at options/opinions. Thanks in advance..
..btw, car is still in Canada..
Old 06-28-2009, 12:07 PM   #2
camaro guy
camaro guy's Avatar
Drives: 2010 camaro LS
should be fine. speedo might be slightly off
camaro guy is offline   Reply With Quote
Old 06-28-2009, 12:10 PM   #3
SilverTurtle
Reality Check Specialist
SilverTurtle's Avatar
Drives: '02 Z28, 2012 45th SS
Send a message via AIM to SilverTurtle Send a message via Yahoo to SilverTurtle
true story
as long as you dont go radically smaller or larger, it wont void your warranty... and as long as you're on a V6 car with the stock brakes, they should fit... its when you go to the SS cars that you run into problems because of the big Brembos at all four corners.
got tequila?
SilverTurtle is offline   Reply With Quote
Old 06-28-2009, 12:21 PM   #4
Vash
Drives: 00 Blazer
There is a calculator on the web somewhere for tire combo's. I forget the URL google for it. You put stock and it gives you options and even speed match and or differences.
I think I saw that on the S10forum dot com somewhere. They do crazy stuff to S10's.
Old 06-28-2009, 12:21 PM   #5
maddymac07
Drives: 2010 camaro 2ss
it will be way shorter and show so much wheel well. not a good idea at all. i sell tires and wheels for a living and trust me it would look very bad
maddymac07 is offline   Reply With Quote
Old 06-28-2009, 12:23 PM   #6
Vash
Drives: 00 Blazer
Call Tire Rack and they could probably tell you what options. I would try to keep the speedo stock.
It will devalue the car in Carfax and the like if you get a inspection hit saying the odo is not accurate.
Old 06-28-2009, 12:40 PM   #7
2010SLVRBULIT
Really not planning on selling it..maybe drop to 45 only(10mm?)..hmmmm..
..speedo and RPMs will be off somewhat..will it improve performance or create more problems w/ the CPU?
Your Warranty Rights The_Blur Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 75 10-19-2012 08:24 PM
Will the V6 have DBW or a good old fashioned cable throttle? theholycow Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 41 08-02-2009 09:25 PM
Edmunds: 2010 Ford Mustang First Look Scotsman General Automotive + Other Cars Discussion 32 11-23-2008 10:55 PM
Warranty Disclosure of Non-GM Products odie23 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 0 10-10-2008 09:40 AM
