Old 05-26-2013, 06:58 PM   #1
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
Does the NPP (dual mode) exhaust boost the ZL1 HP?
Corvettes benefit from this, does the ZL1?
If not why not?
I have been wondering for some time, thanks for the input.
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540
From Oklahoma, Join us on Facebook
https://www.facebook.com/groups/okcamaros/
SamHouseIII is offline   Reply With Quote
Old 05-26-2013, 07:02 PM   #2
KKreme15
KKreme15's Avatar
Drives: C6 Z06
The ZL1 comes with it. The advertised HP is for the complete package. There is no zl1 without it with which to compare it
KKreme15 is offline   Reply With Quote
Old 05-26-2013, 07:03 PM   #3
SamHouseIII
I Carry!
So we lose HP when it's closed?
Old 05-26-2013, 07:05 PM   #4
KKreme15
KKreme15's Avatar
Drives: C6 Z06
It's always open under WOT so that doesn't matter
Old 05-26-2013, 07:05 PM   #5
KKreme15
KKreme15's Avatar
Drives: C6 Z06
You're not in boost when you're cruising around with them closed, either.
Old 05-26-2013, 07:09 PM   #6
SamHouseIII
I Carry!
See your points....stock peak HP is 580
Old 05-26-2013, 09:20 PM   #7
ayousef
ayousef's Avatar
Drives: 2013 ZL1
the valves open at idle to 1000rpms, then shut for cruising then open up once again when you step on it. Someone did a comparison on the corvetteforum and saw no low-end gaisn from having them fully open, so more than anything its just a sound thing.
1150bhp Whipple 4.0 Supercharged 427ci Camaro ZL1
ayousef is offline   Reply With Quote
Old 05-26-2013, 11:45 PM   #8
Performance Enthusiast
Drives: Domestic
The greatest restriction point on the ZL1 factory exhaust system is the converters, so it doesn't matter if the muffler flaps are open or shut from a peak HP stand point.
The NPP option on a 1LE doesn't give any increased advertised HP for this reason.
The NPP was incorporated into the Camaro platform (starting with the ZL1 in '12) for exhaust note purposes.
Performance Enthusiast is offline   Reply With Quote
Old 05-26-2013, 11:52 PM   #9
BigBlock69RS
Ed
BigBlock69RS's Avatar
Drives: 2013 AGM Camaro 2SS/RS/1LE
It sure does make the car sound nice with the fuse pull thou.
BigBlock69RS is offline   Reply With Quote
Old 05-27-2013, 02:51 AM   #10
FINALLYSATISFIED
Est.1775
FINALLYSATISFIED's Avatar
Drives: '15 Challenger Hellcat (sold)
Amen, that it does!
FINALLYSATISFIED is offline   Reply With Quote
Old 05-27-2013, 08:35 AM   #11
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
Does anyone know if the NPP is programed the same on the ZL1 as the other Camaros, or did they us something different.
Old 05-27-2013, 05:47 PM   #12
ayousef
ayousef's Avatar
Drives: 2013 ZL1
I heard that the exhaust controller on the ZL1 is built into the ECU, however the SS camaro's arent supposed to have that exhaust module built into the ECU so maybe its an external module that controls it just like on the previous Z06's and so on.
This is what I personally think and not necessarily true. One way to find out is to see if the valve remains open on the 1LEs at idle.
Old 05-27-2013, 09:08 PM   #13
OldScoolCamaro
...the valves open up around 3,200 RPM. That's when the thunder of the Chevy god's roar to the high heavens.
Old 05-28-2013, 01:25 PM   #14
hognutz
hognutz's Avatar
Drives: 2013 ZL1
If not why not?
on the vette's the cars with NPP are rated 8hp more. In 2008 when i bought my Z51 NPP cars were rated at 438 and non-npp cars were rated at 430.
since the CTS-V is 556 and the only difference is the airbox and exhaust seems logical could be gaining some of the extra power from the exhaust.
2016 2SS
2020 super duty on 37's
hognutz is offline   Reply With Quote
