05-29-2013, 08:10 AM | #1 |
Rev Couture
Drives: 2010 LS Camaro & 2013 Rav4 Ltd Join Date: Jan 2010
First Camaro on EC-7's!!!
Just got these mounted on Memorial Day!
Specs are : Apex Racing flow-forged 18" x 10" EC-7 wheels +25mm offset. apexraceparts.com Nitto NT05 tires - 295/45/R18 Couldn't be happier. I'm not the first Camaro to run Apex Wheels - there are a few guys running the ARC-8's, but I'm 99% positive I'm the first guy to run their new EC-7's Best part is Apex/Nitto wheel/tire combo is 28 lbs lighter compared to my previous set (XXR wheels staggered - 20x8.5 and 20x10 w/ Nitto/ Hankook) Literally could not have done this wheel/tire set up without the help of forum members Li0nel1234 and SUX2BU. Big shout out to them; they were immensely helpful and kept me from ordering the wrong wheel size. And thanks to David at Apexraceparts.com for answering all my silly questions and supplying me with a great product!! Enjoy!
EBC Brakes| DOT 4|Bigworm| SickSpeed| BMR | IPF | Vararam| MRT |MGW | Nitto | Rx |
Iggee |ZL-1 Sways| Hurst | Apex Racing|Past: Srt-4| 6.0L GTO- RIP | '98 Integra |
05-29-2013, 08:31 AM | #2 |
digging the new donuts..
05-29-2013, 09:59 AM | #3 |
Drives: '12 IOM LT 'vert Join Date: Jun 2011
I like it. Are you autocrossing with these?
05-29-2013, 05:37 PM | #4 |
Rev Couture
Thanks.
Yea, thats the goal. Hope to get going by mid-summer. HPDS are on the list too
05-29-2013, 07:01 PM | #5 |
Drives: 2013 1SS Camaro and a truck Join Date: Apr 2011
I like it. Is your car dropped? I wonder how they would look on stock height?
05-29-2013, 08:27 PM | #6 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
Dang loving the 18's would love to have that set up this sunday at autoX chance they fit over brembos?
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
05-29-2013, 10:29 PM | #7 |
Drives: 2013 1LE AGM 2SS RS M6 Join Date: Apr 2012
op are they 10's all around?
05-30-2013, 09:16 AM | #8 | ||
Rev Couture
Yes, 10" wide all around
04-27-2016, 10:03 PM | #9 |
Drives: 2014 2SS-RS NPP Exhaust Join Date: Feb 2015
Did you have to mod the car to get these to fit? I have the ZL1 brakes, do you think they would work with the 6 piston brakes?
04-27-2016, 10:20 PM | #10 |
#PrimeCamaros
Drives: IOM '10 Camaro SS Join Date: May 2014
Those are good looking wheels.
instagram: @IOMsupersport // @PrimeCamaros
04-28-2016, 11:36 PM | #11 | |
2013 Camaro SS1LECTSVZ28
Drives: 2013 AGM 1SS/1LE Join Date: Nov 2012
Second, I have 18"x 10" et25 Apex PS7 on my car and yes you need to do one of 2 things to allow them to fit. You can notch the top of the knuckle at the bottom of the strut to clear the wheel as it just barely touches... OR, In my case with 305/35/18 tires and -2 of camber I had a tire rub issue as well. I opted to install longer wheel studs from a GM truck and a 10mm spacer. I had a 8mm spacer for trial and it worked....but 10mm is more common and cheaper than having customer ones made. Finally you will need hub centric rings as the Apex wheels are made for BMW. I had to snag this proof from the track last Sunday as I don't have any pics of the car with them on ... Photo credit Walter Cronk
05-03-2016, 12:28 AM | #12 |
Thanks dropspeed.
Do you think an 18 x 9 would clear without grinding the knuckle or running spacers? I'm thinking about running 275/40-18 on 18 x 9 Apex wheels. Also, can you recommend a vendor for hub centric spacers? |
05-03-2016, 07:07 PM | #13 | |
42 is a no go at all......The 9 with 31 offset will bring it out 7mm from the knuckle.....It will be close, but it should not rub. the 275width will not be an issue. This is just a hobby for me....I would call Apex to verify. I would bet they have sold a 9 with 31 offset for the front of a Camaro Matt
