Old 06-02-2013, 02:21 PM   #1
Whipped416
Whipped416's Avatar
Drives: 2010 CAMARO SS
whipple BIG tensioner part number
i am looking for the part number for the bigger whipple tensioner that comes with the whipple 10 rib setup.. i see it is a dayco tensioner only numbers i see is 1721230270... and on the back it has a F 15 1202 C&H... i search and cant come up with anything.
Anyone know this part number ?
Whipped416 is offline   Reply With Quote
Old 06-02-2013, 02:39 PM   #2
Birm
Birm's Avatar
Drives: Florida Speed & Power
Texas Speed sells them don't they? Maybe call and ask?
Birm is offline   Reply With Quote
Old 06-02-2013, 03:20 PM   #3
Whipped416
Whipped416's Avatar
i was gonna call dayco tomorrow but i was seeing if anyone knew.
Old 06-02-2013, 03:41 PM   #4
429
Drives: 2010 camaro ss
ECS is probably the best place to call about that.
429 is offline   Reply With Quote
Old 06-03-2013, 07:39 PM   #5
Whipped416
Whipped416's Avatar
ok part number is 89270...
replacement part is 89446 which is actually stronger the the 89270 from what dayco told me.
i went ahead and bought the 89270 just to be on the safe side.. i will buy a 89446 and try it and keep it as a backup as well
Old 06-03-2013, 08:29 PM   #6
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
is there any way to get the bracket that holds the tensioner at a good price?
2018 Camaro SS A8 Edelbrock 2650 FBO 93 octane 9.54@144 Pump E 9.12@156
2010 Camaro
Stock bottom end with 46,000+miles JRE remote tuning Whipple A6 and Drive it to and from the track 9.46@146
94guy is offline   Reply With Quote
Old 06-03-2013, 09:22 PM   #7
Whipped416
Whipped416's Avatar
i have one for the old 6 rib setup looks new 1800 miles on it .. if u need one for the 10 rib u have to call mike with whipple.. its around 120 bucks i think..
only difference in the 2 is the hole size that holds the tensioner.
Old 06-03-2013, 10:11 PM   #8
NOT URSS
NOT URSS's Avatar
Drives: 2010 2SS/RS Camaro
Send a message via AIM to NOT URSS
thanks for info!
632RWHP/556RWTQ
NOT URSS is offline   Reply With Quote
Old 01-28-2014, 10:38 AM   #9
PMJ
Seeking 9s on M6...
PMJ's Avatar
Drives: 2012 2SS/RS LS3 aka "BlackWidow"
Blake, did you get the 89446? does it fit? Is it stronger? I broke my tensioner at track last weekend...was actually able to rig it up and still make runs. But looking for stronger replacement now...
PMJ is offline   Reply With Quote
Old 05-07-2014, 09:09 PM   #10
SSlim
Drives: 2011 Cyber Grey 1SS/RS A6
So did the 89446 work as a replace to anyone? Mine is going out.
Whipple, GT9 cam, LS3 conversion, ZL1 pistons, ZL1 rods, Circle D converter, Stage 3 trans, Tuned by Pat G, CAI inc, TPS headers, posi mod, Dynomax bullet cat back, VMAX TB, ADM Scoop, RX catch can, Eibach prokit plus, Eurotek Mesh 33 wheels, P13w DRLs, Pioneer/Massive Audio/Vibe/JL interior goodies.
613 RWHP/596 TQ
SSlim is offline   Reply With Quote
Old 05-10-2014, 04:25 PM   #11
PMJ
Seeking 9s on M6...
PMJ's Avatar
I made the 89446 work, but replaced the pulley from the stock tensioner.
Old 06-05-2014, 08:12 AM   #12
WiredAVS
WiredAVS's Avatar
Drives: '21 TRx '22 ZLe
Does the pulley need to be changed due to size?
2014 Camaro 2SS/1LE AGM/768rwhp
Recaro's, Custom Autometer Gauges, Hotchkis 1" Lowering Coils, CAi Intake, Elite Catch Can's, 1 7/8" StainlessWorks LT's w/Hi Flo Cat's mated to factory NPP Exhaust, 160* Thermo, NightFury Cam, 2.9l Whipple on Meth @ 11lbs, JoeGibbs LS30 in the CrankCase, Built by Nick, Steven, and Tuned By Shawn at Lethal Racing....
WiredAVS is offline   Reply With Quote
Old 06-05-2014, 09:03 AM   #13
SSlim
The pulley on the new one is not as wide as the old so you have to swap. I also had to put a washer behind mine to shim it so the entire belt was on the pulley. Before like an 1/8" was having off and cutting in to the belt.
I also have the part number for the stock replacement if you want that. Whipple gave me the number and said it can be found on amazon for about $55
613 RWHP/596 TQ
Old 06-05-2014, 09:33 AM   #14
WiredAVS
WiredAVS's Avatar
That would be awesome SSlim! Nothing wrong with my stock one. I want to have it painted and another pulley would allow me no down time...
Curious, why didn't you go back with the stock replacement? Is the 89466 that much superior?
Thanks!
