Old 06-18-2013, 03:34 AM   #1
Walrus12kp
Drives: 2013 Camaro 2ls
subwoofer help
I own the 2013 Ls and it comes with an ok stero system that is in need of an upgrade.
Firstly, i would like to get a subwoofer so I can get some bass but i need a little room in my trunk for my golf clubs so i looked at
http://www.crutchfield.com/p_206SCAM...er.html?tp=113
would this be a good fit or should i look into putting together my own sub.
Secondly i was wondering the diffucluty of changing the speakers in the car as well. i find that my max volume isnt that loud at all.
I do not know anything about car stereos but my dad has changed and replaced many so he will help me install anything. i just need to know what products to buy and and the diffulcutly of install. PLEASE HELP!
Walrus12kp is offline   Reply With Quote
Old 06-18-2013, 11:48 AM   #2
the barber
the barber's Avatar
Drives: 13' Sw 2ss Ls3
Here u go 2 10" subs with an enclosed sub box and 2 golf sets fit in there still all used was a high to low level converter tapped in at factory amp if u don't have BA system u can tap into the 6x9s and of course all ur wiring and system setup component's
the barber is offline   Reply With Quote
Old 06-18-2013, 12:00 PM   #3
family man
Drives: .
Do not buy from Crutchfield, they are so damn expensive. Check out ********, they are a vendor on here and have everything to hook you up.
www.********.com
family man is offline   Reply With Quote
Old 06-18-2013, 12:07 PM   #4
the barber
the barber's Avatar
Either that or buy from a top rated eBay seller I bought both Rockford Fosgate 10" p2 subs for less than what one retails for
Old 06-18-2013, 12:21 PM   #5
Walrus12kp
what box did you use? can I have a Link?
Old 06-18-2013, 03:19 PM   #6
the barber
the barber's Avatar
Just some random box my buddy had laying around at his shop ill get dimensions on it right now
Old 06-18-2013, 03:30 PM   #7
the barber
the barber's Avatar
It measures 24.5" long 12" tall and 14" deep almost 2.4 cubic ft of air space 1.18 per side, there's a center divider in the middle
Old 06-18-2013, 04:08 PM   #8
crashprime
Drives: 2010 Camaro 1SS IOM M6
http://www.caraudioco.com/rockford-fosgate-p300-10.html
$200 for your amp and sub.
http://www.walmart.com/ip/Scosche-68...-Amps/14667122
Grab a scosche kit from Walmart for $25, wire to the battery, tap from the 6x9's for your signal.
Fits perfectly, will sound great, won't break the bank.
crashprime is offline   Reply With Quote
installation, stereo, subwoofer
