Old 07-01-2009, 10:03 PM   #1
PonyMan
PonyMan's Avatar
Drives: 2009 C6 4lt Vert, 2011 Camaro Vert
Bowties Painted IOM
Painted the front and back bowties IOM today to match my stripes!!!
PonyMan is offline   Reply With Quote
Old 07-01-2009, 10:06 PM   #2
nasty2ss
nasty2ss's Avatar
Drives: 2010 camaro 2ss IOM
that looks very cool or i guess hot is the word
nasty2ss is offline   Reply With Quote
Old 07-01-2009, 10:10 PM   #3
GothamCamaro
Then you're gonna love me
GothamCamaro's Avatar
Drives: 2010 Black Camaro Tumbler RS
Nice paint job on those bowties, was wondering how orange would look for a IOM Camaro.
Own- "Does it come in Black?" Exterior/ Grey Interior 2LT/RS Automatic
_____________________________________
The Batman would only drive a 2010 Camaro and buy from Camaro Scotty. 'Nuff said.
Anyone that knows of a place that is making the Concept Shifter for the new Camaro. (Auto specifically) Please let me know.
Order# NDTMVP Ordered 10/23/08.
2000 on 5/21/09... It begins.....
4B00 on 6/26/09... In transit to the Cave
5000 on 7/6/09 it waits for my arrival!
1000000 on 7/10/09 The Tumbler is in the Cave!
GothamCamaro is offline   Reply With Quote
Old 07-01-2009, 10:10 PM   #4
bluch
OH CANADA!
bluch's Avatar
Drives: 2011 RAM 1500 LARAMIE
Had to trade in the Camaro for a truck :(, but hopefully I can join the Camaro family again one day
bluch is offline   Reply With Quote
Old 07-01-2009, 10:14 PM   #5
bob2the2nd
Drives: CGM 2LT RS
alright i have to know how are people painting these. i REALLY want to do it, and was thinking just model paint and use a small detail paint brush but i have no idea.
help.. PLEASE
2LT CGM auto/sunroof/RS
1100: 11-29-08
6000: 6-29-09
cracked windshield: 7-1-09
1000 miles 7-4-09
windshield replaced: 7-9-09
2000 miles 7-10-09 (yep 2000 miles in 11 days)
3000 miles 7-16-09
4000 miles 7-30-09
bob2the2nd is offline   Reply With Quote
Old 07-02-2009, 09:28 AM   #6
FriedCherry
Drives: 2010 2SS/RS IOM/IO Camaro
help.. PLEASE
Same
FriedCherry is offline   Reply With Quote
Old 07-02-2009, 09:44 AM   #7
Red Hot SS
Red Hot SS's Avatar
Drives: 2010 Victory Red 2SS/RS M6
nice very nice.
to those asking about paint: VINYL is the way to go. Its done in about 5-10 minutes. If you screw up you can rip it off and try again. its not permanent if you dont want it to be.
Virginians Join Group: Virginia is for (Camaro) Lovers!
VIN: 2G1FT1EW8A9118043
Finally Home! (6/16)
Red Hot SS is offline   Reply With Quote
Old 07-02-2009, 10:21 AM   #8
PonyMan
PonyMan's Avatar
help.. PLEASE
Trust me I am no paint guy!!! You can go to Paintscratch.com and get a kit, or just the paint. I ordered IOM paint and clear coat in 24oz spray cans from them (about a week and half to receive), and I already had auto primer.
The front bowtie removes very easy (search forum), the rear bowtie I painted on the car. Make sure you use good painter’s masking tape, not that thin cheap stuff at your local hardware store.
You can ruff up the gold/clear part of the bowtie with a fine sand paper (400g, 600g). I mask the bowtie off first, and then cut away the area you want to paint, and then I sand it lightly. Sanding it unmasked, you may scratch the plastic chrome around the bowtie. When cutting away the part of the tape on the bowtie you want to paint, use a new razor blade, and follow the chrome edge/slot.
After you have covered everything up that you don't want painted, double check yourself, primer, paint, and clear coat has a habit of finding places you have forgotten. Make sure after you have ruffed up/sanded, you clean the area of any matter, and grease. Apply your primer, if you have a fan it helps the drying process, I applied three coats (easy on the first two coats). Next is the basecoat color, same process as the primer - making sure you let the paint dry in between each coat, don't rush it. When you start to apply the clear coat, you feel like a pro by now, but don't let you guard down now. One little slip, tip, or flick can damage all your hard work.
After the last coat of clear coat has gotten past the tacky stage, remove the masking tape - VERY SLOW & EASY!!! I put the fan on the area over night, and let the paint cure/harden. After the paint has hardened, you can take a rubbing compound, and put a shine on the clear coat (or don't, for a semi/flat look). Some people will also wet sand in between each coat of primer, base color and even clear coat (it is up to you).The process above works for me, I hope you can use all or some of the above steps in your bowtie painting process.
Old 08-21-2009, 09:03 AM   #9
PonyMan
PonyMan's Avatar
I have had a couple of PM's asking about my painted Bow Ties, so I guess you can view this as a "BUMP" and hopefully it will help other forum members.
"Trust me I am no paint guy!!! You can go to Paintscratch.com and get a kit, or just the paint. I ordered IOM paint and clear coat in 24oz spray cans from them (about a week and half to receive), and I already had auto primer.
After the last coat of clear coat has gotten past the tacky stage, remove the masking tape - VERY SLOW & EASY!!! I put the fan on the area over night, and let the paint cure/harden. After the paint has hardened, you can take a rubbing compound, and put a shine on the clear coat (or don't, for a semi/flat look). Some people will also wet sand in between each coat of primer, base color and even clear coat (it is up to you).The process above works for me, I hope you can use all or some of the above steps in your bowtie painting process."
Old 08-21-2009, 09:07 AM   #10
SSRS2010
SS/RSVIN04274
SSRS2010's Avatar
Drives: 2010 CAMARO.
SSRS2010 is offline   Reply With Quote
IOM 2SS/RS with painted ground effects chevygirl1 Camaro Photos | Spyshots | Video | Media Gallery 35 05-18-2011 04:54 PM
IOM Painted grill Superman09 Cosmetics and Lighting Modification Discussions 37 07-17-2010 12:43 AM
Do the IOM with IOM interior have IOM door panel inserts, and dash trim? dragonZ28 5th Gen Camaro SS LS LT General Discussions 14 11-12-2009 10:22 PM
Finally saw a 2SS IOM in person- thoughts Ghost Rider 5th Gen Camaro SS LS LT General Discussions 19 06-08-2009 09:47 AM
IOM Exterior with IOM Interior AirBoyzT 5th Gen Camaro SS LS LT General Discussions 29 01-09-2009 10:48 AM
