Old 06-28-2013, 12:23 PM   #1
camarostar2010
Drives: 2011 SS
Interesting read : oils and viscosity
This is an article I ran across. I figured a guy who owns over 2 million dollars in cars has a few things to think about when it comes to oil AND now I am more confused see link below
http://www.ferrarichat.com/forum/faq...=haas_articles
camarostar2010 is offline   Reply With Quote
Old 06-28-2013, 06:02 PM   #2
Avenging Orange
Avenging Orange's Avatar
Not confused one bit. Looks to me that the statement, most oils are pretty much the same (in same classification), works for me. I have always said, when in doubt, use what it came with for normal driving.
Very interesting read, thanks
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 08-10-2013, 04:42 AM   #3
Lemmy
Drives: 2010 GT500
Don't worry about all that. If your owner's manual calls for 5W-30, use a high quality synthetic I seriously doubt you will see a huge difference in your engine life and performance if you use Pennzoil Platinum 5W-30 synthetic or Mobil 1. My manual calls for 5W-50 which this article basically shuns. Thinner is better, but why does my OM call for something so thick?
Lemmy is offline   Reply With Quote
Old 08-12-2013, 08:02 PM   #4
LS3 Handler
I love the LS3
LS3 Handler's Avatar
Drives: 2010 IOM 2SS Manual
Basically how I read it was that all oils don't protect well under normal operating temps. and that's true its noted that most engine wear comes during the time the motor is trying to reach normal operating temps. So be easy on your motor until its warmed up. But it goes on to say that basically in synthetic motor oils that 0w-30, 5w-30, 10w-30 or whatever ?w-30 that they all have the same lubrication and wear protection above 100 degrees or at normal operating temps. But the lower the prefix e.x. 0w-30 is better at protecting the motor at under 100 degrees so you get less wear during start up because the oil flows better when its cold and lubricates better but has the same lubrication and wear prevention as 10w-30 during normal operating temps. So basically 0w-30 would be better for the normal driver even the ones that take it to the strip because its the hotter oil temps that need the thicker oil as in ?w-40 or ?w-50 because the last number indicates the need for the added high temp protection (over 275 degrees oil temp) that the 40 and 50 weight oils have.
LS3 Handler is offline   Reply With Quote
