![]() Drives: 13 AGM ZL1 Join Date: Jun 2013
New guy with a chiller question
I've got about 2800 miles on my ZL1 and the car is incredible. The only issue I have is the loss of power in the heat of the day. I would like to get a feel for how many of you have a chiller. I would like to do a pully upgrade but I think it would be best to address the heat exchanger or add a superchiller. Any input on either is appreciated.
knows 2 facts about ducks
The RX super chiller is proven to lower temps and decrease ETs.
Drives: 2010 Camaro Join Date: Feb 2010
Hahaha lol, yea - decrease. My bad
#6 |
Haha wouldn't expect anything less.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2014 ZL1m6 red hot #569 Join Date: Dec 2009
ive made back to back runs with mine and its the cars engine coolant that gets too hot before the supercharger coolant does. I also showed 20 h.p gain on the dyno. very happy with my rx/chiller!
#8 |
Correct me if I am wrong but I think he meant back to back runs with and without the chiller to verify a difference in e. t.
I base most of my mods of the reviews of the people who have already installed/used the products. I would prefer to add a chiller as opposed to upgrading the heat exchanger but it seems only a select few people have done the chiller and I don't know if I am missing something. Are there issues with the chillers? |
#9 | |
Slip 1. Pass with the chiller off. Slip 2. Pass with the chiller on. Before run 1 I'm hoping that you got the ect to the operating level. Then the comparison would be good. Posting what you did is meaningless. Please, just the facts ma'am. |
#10 |
Yes that would be great. I have not seen anything that proves an increase in hp at temp or any faster times with the same weather conditions.
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Camaro's, always have, always will. Join Date: Oct 2010
...detriment with the ZL1. Heat soak. Get it up to operating temp with the computer awake and onboard with what your plan of action is. A couple passes does the trick. Then, get it in....but it won't be a hard charger on the strip for too long in stock form unless you cool the charge with mods.
#12 | |
![]() Drives: 05 GTO / JETTA TDI Join Date: Jan 2012
![]() Not to be confused with the copy RX was making. Here are some pics of our new Xtreme Chiller on Turbo99 2010 SS 680hp Maggie ![]() ![]()
#13 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
I don't know if anyone can verify this but I have been told that anytime the throttle is beyond 85% the electronics turn the a/c compressor off. I'm not certain this is true but suspect it is because I tried to run the a/c on the road coarse when temps were over 100 degrees and it did not work well at all. If that is in fact true, then anytime the throttle is over 85% then the chiller cannot do anything because the a/c compressor will be off.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. ![]() |
#14 | |
![]() ![]() ![]() ![]() Drives: 2017 ZL1 A10 Join Date: Aug 2009
Ahmad
2017 ZL1 A10 SW (SOLD)
Whipple 2.9 with 3.2 Pulley, Weapon-X Stage 3 Cam, FIICHILLER ,LG Motorsports LT, Borla S type, ROTFAB Big Gulp, Big 3 Reservoir Glassskinz rear window valance . 2012 ZL1 A6 (SOLD) Forged 376 CI, LSA HeartBeat, Mast Medium Bore Heads & JDP ZLR Cam, ARH LT , MagnaFlow Resonated X + Borla Atak Catback, ADM 102mm Snout, CAI, NW102MM TB, ID850, Fore Triple Fuel Pump, MSD Wire's, Moroso CC. Alky Control, FIICHILLER. |
