Old 07-02-2013, 04:49 PM   #1
GAHDOOSH
GAHDOOSH
GAHDOOSH's Avatar
Drives: 2016 Camaro 1SS
Wiring HELP?!?!
I am adding a camera to the front and back window.
I am looking for the following:
  • An ACC(or remote wire)
  • A constant wire
  • And a ground wire
Obviously I need to find these wires at the front and the rear of the vehicle.
Any suggestions would be enormously helpful
Thanks
GAHDOOSH
2016 1SS 6.2L LT1 Manual 6-Speed, Front Emblem Blackout, Rear Bowtie Delete, Side emblem delete, Phastek Side Marker Tint, GM Black Taillights, $23.57 of Premium Gas this morning
GAHDOOSH is offline   Reply With Quote
Old 07-02-2013, 05:57 PM   #2
Nightspore68
Nightspore68's Avatar
Drives: 2013 Camaro ZL-1, Victory Red
Shouldn't you be able to use the reverse light wires for the rear camera? They'll be automatically switched for you.
Nightspore68 is offline   Reply With Quote
Old 07-03-2013, 08:35 AM   #3
GAHDOOSH
GAHDOOSH
GAHDOOSH's Avatar
It is likely that the reverse camera is only given power when you shift into reverse, but I'm looking for something inside the car like near the rear speakers.
GAHDOOSH
Old 07-03-2013, 01:03 PM   #4
DraggnFrameGMC
DraggnFrameGMC's Avatar
Drives: 2011 Synergy Green Camaro LT
Ignition - Pink BCM green 25 pin plug pin 6
12 volts - red/white BCM white 26 pin plug pins 2 and 3 or bcm blue 27 pin plug pin 4
ground - a duh
Just run them to the back.
DraggnFrameGMC is offline   Reply With Quote
Old 07-04-2013, 12:11 PM   #5
yzark99
I run 2 catch cans...
yzark99's Avatar
Drives: 2012 1LT SIM Auto
Rears:
Accessory: under the rear armrest cap is a green wire for the 12 volt power point. It is fused, and only comes on when the keys are in the ignition. Run an extension from this under the carpet and rear seat to your desired location. To get really fancy, wire a switch into this line.
Constant: run a smaller wire from the battery and follow the big wire track towards the rear shelf.
For ground, there are some studs under the rear deck that are excellent. I am using them with my amps. I tested them, and they have really good connections to the battery.
Wires can be run up the sides of the trim around the pass-through opening to get to the rear shelf.
Overkill tuned • Air Scoop • CAI • VMAX PTB • JacFab Laminator FX + Extendolator • SOLO Hi-Flo Cats + Cat-Back Exhaust
View my top 3 LFX performance mods and more:
yzark99 is offline   Reply With Quote
Old 07-09-2013, 12:03 PM   #6
GAHDOOSH
GAHDOOSH
GAHDOOSH's Avatar
Thanks, that worked perfectly.
Unfortunately the cameras were crap so I wont get it working for another week now anyway lol
GAHDOOSH
