![]() Drives: C5 Convertible Join Date: Mar 2009
Corvette Convertible - 9-Second Twin Turbo Street Sleeper “Vetzilla"
This vehicle is being listed for a friend.
Buy it now on eBay for $34,900! Click here for the auction This 2000 Corvette Convertible is Millenium Yellow with a black convertible top and custom black and yellow leather interior. ![]() This 2000 Corvette has all of the “Show and Go” you could ask for and is available at a fraction of the cost it would take to duplicate. Known as Vetzilla, this 9-second car can be street driven and still has all factory creature comforts, including A/C and runs on 93 octane pump gas and methanol. It is in excellent condition, showing approximately 35,000 miles on the odometer and fully loaded minus electronic climate control. Below is a list of “GO” modifications Custom Machined LS1 Block OEM Crankshaft Balanced and Machined Manley Forged H- Beam Rods Mahle Fored Coated Pistons AFR Ported 225 Cylinder Heads Comp Cams Competition Rockers w/ Patriot Valve Springs Custom Grind Turbo Camshaft TTI Stage X Twin Turbo Kit w/ Upgraded Ball Bearing Turbos (capable of 25+ lbs of boost) AMW Catch Can 60# Motron Fuel Injectors Engine Oil Cooler Custom Fuel System featuring: -Boost Referenced Pressure Regulator -KB Boost-A-Pump -LPE High Output In-Tank Fuel Pump ESC Dual Nozzle Methanol Injection Kit FLP Level 5+ 4L60E Auto Transmission w/ Trans Brake Precision Industries Custom Torque Converter Differential Strut 3.42 Rear End w/ Hardened Shafts Custom Stainless Exhaust Bassani “X” Pipe Corsa Exhaust Blitz SBC-ID Color Display Boost Controller w/ Wideband Logging LPE Mini-tub Braided Stainless Steel Brake Lines Drilled and Slotted Rotors Hurst Roll Control – Line Lock Below is a list of “SHOW” modifications In 2011, the vehicle was completely disassembled and received a complete show quality Millenium Yellow Repaint. ACP Heat Extractor Hood Tigershark Front Clip w/ Spoiler and PIAA Driving Lamps Z06 Brake Ducts OZ Superleggera Racing Wheels (18 x 10 front / 19 x 13 rear) Nitto Tires (Sale also includes extra set of rear tires - $1,000 Value!) Vette Essentials Two Tone Steering Wheel Vette Essentials Two Tone Center Console Vette Essentials Two Tone Arm Rests Vette Essentials Custom Two Tone Embroidered “Vetzilla” Leather Seats 2 Pod “A” Pillar w/ Autometer Phantom Boost & Fuel Pressure Gauges Carbon Fiber Radio Surround Aluminum Instrument Cluster Bezels Tinted Glass Below is a list of “Audio” modifications Kenwood Head Unit w/ Navigation MB Quart Speakers 12” Subwoofer Kenwood Excelon Amps ![]() ![]() ![]() ![]() ![]() Thanks for looking! -Rick |
