Old 07-05-2013, 05:36 PM   #1
Dynamite
Dynamite's Avatar
Drives: 2013 Camaro 2SS/RS XD
Oil Change fail, broken bolt head
I broke the bolt on the oil drain pan while I was getting ready to drain the oil. The head is completely broken off. Any tips for getting the stud out.
Or should I just have the car towed to a dealership?
Edit: Crisis averted. I was able to use a pointed screw and move the stud out.
Dynamite is offline   Reply With Quote
Old 07-05-2013, 06:39 PM   #2
joeybsyc
joeybsyc's Avatar
Drives: 2010 Aqua Blue Metallic 2SS
How did you manage to break the head off the oil drain bolt while taking it out??
I think you should consider going to Jiffy Lube from now on.
joeybsyc is offline   Reply With Quote
Old 07-05-2013, 07:11 PM   #3
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
If there's nothing to grab, you're going to have to drill the center of the bolt out to put in an E-Z Out and turn it out with that. Hopefully there's enough room to get a drill in there, otherwise you'll be looking at buying a right-angle drill. E-Z Out sets at Harbor Freight and elsewhere have a few sizes in them along with left-hand drill bits (run in drill set on reverse). Sometimes you get lucky and the drill bit will catch and back out the bolt.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 07-05-2013, 08:31 PM   #4
Dynamite
Dynamite's Avatar
I mixed my left and right up, so I just over tightened it until it broke off.
Old 07-05-2013, 09:16 PM   #5
cadyshac
It's in the hole!
cadyshac's Avatar
Drives: '11 2SS L99 SGM, '18 2SS, M6, HWSE
If the oil is still in the car take it to a trustworthy shop. This is not the job for you to learn how to remove a broken bolt.
cadyshac is offline   Reply With Quote
Old 07-05-2013, 09:57 PM   #6
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
just for total neophytes here - the correct procedure is counter clockwise to loosen, correct?
Glen e is offline   Reply With Quote
Old 07-05-2013, 10:11 PM   #7
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2011 2SS/RS/A6 cammed-n-whippled
lefty-loosey, righty-tighty.
POWERFREAK is offline   Reply With Quote
Old 07-05-2013, 10:36 PM   #8
Dynamite
Dynamite's Avatar
I fixed the issue and changed the oil before anyone posted. I don't know how to delete this...
Old 07-16-2013, 04:22 PM   #9
SSGUNNER
Chu no guat a hasa is?
SSGUNNER's Avatar
Drives: 14 Jeep G Cherokee Overland HEMI
Isnt that what it normally is for everything that needs to be screwed off? Lol.
Well except maybe the rx cc. That thing was a pain.
11 2SS/RSL99No Longer Stock (Sold) 6/19/14:AAC Plasma DRL's | Plug n play harness | Elite CC | Tint: 35% & 5% | LED Dome light | Show-N-Go Plate Holder | Flowmaster AT | C.A.I. Intake | VMAX CNC Spiral Ported TB | Husky Splash Guards
SSGUNNER is offline   Reply With Quote
Old 07-16-2013, 07:25 PM   #10
SSMickey
SSMickey's Avatar
Drives: 2010 IBM 2SS
You got damn lucky. Surprised the threads on the oil pan didn't pull out before you broke the head off the drain plug.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 07-18-2013, 06:25 AM   #11
pincoin
Camaro owner since 1982
pincoin's Avatar
Drives: 2012 Camaro 2SS-RS Conv IBM L99
You are very lucky to have gotten it out with no damage to the pan
2012 Camaro RS-SS Conv IBM, L99
1968 Camaro RS Coupe 327 AT
1968 Camaro RS-SS Conv, sold 1993
pincoin is offline   Reply With Quote
Old 08-19-2013, 01:23 PM   #12
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
While this is a noob manoeuver, the only way to learn doing stuff yourself is to break things. You'll never make this mistake from on!
Good luck!
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 08-26-2013, 06:46 AM   #13
IowaGuy
IowaGuy's Avatar
Drives: 2013 Cyber Gray Metallic Chevy Volt
Believe me when I say that there are many guys more new than you doing things to their camaros for the first time. Sometimes horrible things. The car inspires people to learn how to take care of it personaly. Its not like just droping the bonneville off at the shop.
Your fail will probaly actually save someone else from doing the same thing, so no reason to delete imho.
I have come to realize that my wife's a mod addict. Instead of a camaro she has the house, and instead of camaro5 she has HGTV.
IowaGuy is offline   Reply With Quote
