Old 07-08-2013, 05:39 PM   #1
Khmero215
Khmero215's Avatar
Drives: Victory Red 2SS
fuel pump question
If I get bigger injectors, should I change my fuel pump too?
Khmero215 is offline   Reply With Quote
Old 07-08-2013, 05:47 PM   #2
K32 Camaro
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6
It depends on the fuel needs. Be specific.
K32 Camaro is offline   Reply With Quote
Old 07-08-2013, 05:49 PM   #3
lewylew
lewylew's Avatar
Drives: 2010 ZL550& 2021 C8 Z51
Not sure if it is needed. I am using ID850 injectors. I went with a zl1 pump and a MSD BAP. Only upgraded because of leaning out.
lewylew is offline   Reply With Quote
Old 07-08-2013, 05:50 PM   #4
K32 Camaro
V8 lounge member #5
I doubt it. What hp are you running?
Old 07-08-2013, 05:50 PM   #5
Khmero215
Khmero215's Avatar
I am too thinking to upgrade to ID850's. and also was gonna go with the zl1 pump as many have the same setup. but do they go hand in hand. If iswapped the injectors, would the fuel needed to be done at the same time
Old 07-08-2013, 05:51 PM   #6
Khmero215
Khmero215's Avatar
at the moment, I'm at 530rwhp
Old 07-08-2013, 05:55 PM   #7
K32 Camaro
V8 lounge member #5
You're still on the stock injectors? Yes I would upgrade.
Old 07-08-2013, 06:04 PM   #8
Khmero215
Khmero215's Avatar
upgrade both? at the same time?
Old 07-08-2013, 09:08 PM   #9
ITGuy11
Burning up tires
Drives: 2023 ZL1 Vert
Make sure that you get the ADM controller and adjust your tune to take advantage of that zl1 pump.
ITGuy11 is offline   Reply With Quote
Old 07-08-2013, 11:32 PM   #10
ADM PERFORMANCE
Drives: Anything I want
Exactly
ADM PERFORMANCE is offline   Reply With Quote
Old 07-09-2013, 08:05 AM   #11
AL1SS/RS
AL1SS/RS's Avatar
Drives: 2012 camaro 1SS/RS LS3
I think he might be have the 52 ld injectors .
AL1SS/RS is offline   Reply With Quote
Old 07-09-2013, 10:20 AM   #12
Birm
Birm's Avatar
Drives: Florida Speed & Power
At this HP you are fine with the ZL1 pump....
Birm is offline   Reply With Quote
Old 07-09-2013, 10:17 PM   #13
epstein
Drives: SS/RS
Send a message via AIM to epstein
Do it right..... get the pump and the controller......and install all at once and a tune to optimize it all.
epstein is offline   Reply With Quote
