Old 07-10-2013, 07:02 PM   #1
camaro-heater
22 years of slammin gears
camaro-heater's Avatar
Drives: 2010 Camaro SS M6
Difference in suspension with SS and 1LE
What are the main differences between the 1LE's suspension and the SS? Have any of you upgraded to 1LE suspension?
2010 1SS/RS-M6 > SIM w/matte black stripes.
Engine/Performance> Magnuson TVS2300 @ 8lbs-Hennessey CAI-SLP 1 3/4" longtube headers w/ HF cats X pipe SLP Powerflow muffler-QTP dual oval electric cutouts-ZL1 fuel pump-RX catch can-ADM race air scoop,WW relocate-Hurst short throw shifter-
Tuned by: Boost Performance 550rwhp/538tq.
Drivetrain> DSS 3.5" aluminum ds-Street Slayer Twin Carbon-IdealG master cylinder-Tick ss clutch line&speed bleeder-GFORCE 1500 Outlaw axles-JRE rear end pkg(LPE 3.70's,true trac,billet main caps)-LPW rear cover-Nitto NT05's. Suspension> Minor stuff/bushings
camaro-heater is offline   Reply With Quote
Old 07-10-2013, 07:06 PM   #2
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
http://www.camaro5.com/forums/showthread.php?t=212140
The 1LE also features exclusive, monotube rear dampers instead of the twin-tube dampers on SS models. The new hardware allowed engineers to tune the 1LE suspension to focus on optimal body-motion control while preserving much of the ride quality and wheel-motion control of the Camaro SS.
Other changes to optimize the 1LE for track-day use include:
- Larger, 27-mm solid front stabilizer bar, and 28-mm solid rear stabilizer bar for improved body control
- Higher-capacity rear-axle half shafts to cope with increased levels of traction
- Strut tower brace for improved steering feel and response
- ZL1-based 20 x 10-inch front and 20 x 11-inch aluminum wheels
- 285/35ZR20 Goodyear Eagle Supercar G:2 tires front and rear (identical to the front tires for ZL1)
- ZL1 wheel bearings, toe links and rear shock mounts for improved on-track performance
- ZL1 high-capacity fuel pump and additional fuel pickups for improved fuel delivery during high-cornering
Old 07-10-2013, 07:10 PM   #3
aggieguy13
aggieguy13's Avatar
Drives: 2013 SS/RS VR 1LE
-Suede Flat bottom steering wheel.
- suede short shifter from zl1
-"camaro" labled Red Brembo 4-piston Calipers
-3.91 final drive. along with closer gear ratios
2013 SS/RS 1LE VR-Backup System, SOLO Perforsance HF Cats, Muffler Delete, BBK Off-road X-pipe
2002 35th Aniversary SLP SS-Sold
aggieguy13 is offline   Reply With Quote
Old 07-10-2013, 07:11 PM   #4
Stud
Stud's Avatar
Drives: 2012 1LT RS RY
^That's not suspension
Stud is offline   Reply With Quote
Old 07-10-2013, 07:12 PM   #5
slick rick
SoCal Mayhem
slick rick's Avatar
I'm waiting for GM to release a price on the 1LE track pack
1LE Track Pack is 23102311
Old 07-10-2013, 07:17 PM   #6
aggieguy13
aggieguy13's Avatar
neither is fuel pump, wheels, rims
Old 07-10-2013, 10:51 PM   #7
Biscuitpie
Biscuitpie's Avatar
Drives: '11 Cammed LS3, '14 Scion FRS
Wheels and tires might as well be even if they technically aren't.
SOLD with a Z06 in the not too distant future: Cammed, boltons, axles, lowered, and more. | 476 WHP
Biscuitpie is offline   Reply With Quote
Old 07-11-2013, 01:07 AM   #8
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
The rear sway bar won't fit on your 2010. GM changed the mounting points for the rear sway bar in 2012. The rest of the 1LE package should be OK though. GM will likely price the individual 1LE package high and it would probably be cheaper/better to buy an aftermarket kit.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
2014 White Caprice PPV
-6.0 L77, 6L80E, 2.92, G80
LimaCharlie is offline   Reply With Quote
Old 07-11-2013, 01:50 AM   #9
Bonemaro
Drives: 2010 RJT 1SS M6
Send a message via AIM to Bonemaro
That's strange. I added the ZL1 rear sway to my '10 SS and just needed the end links.
Bonemaro is offline   Reply With Quote
Old 07-11-2013, 06:40 AM   #10
sycraft
COTW 5/06/2013
sycraft's Avatar
The package part number is for reference, you will need to order the individual parts you want for now. the 2010 will use the ZL1 rear bar, just may need the updated rear lower control arms which are pretty reasonable.
Old 07-11-2013, 09:59 AM   #11
67motorcat
Blown Cool Breeze
67motorcat's Avatar
Drives: 2011 Black on Black 2SS M6
That is not possible even on 2011 models....unless your rear control arms have been changed at some point in time.
Have you owned your Car since it was new?
Had a 2010 IBM 2SS M6
Enjoy life.Think of all the women on the Titanic who passed up dessert.
67motorcat is offline   Reply With Quote
Old 07-11-2013, 10:16 AM   #12
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
If anyone prices a dealer "SS to 1LE" conversion with everything minus the transmission, steering wheel, and shifter, I would love to hear it. I looked into a trade of my SS for a 1LE and the loss would be around $15K all in. Not worth it to me.
BTW when I changed my trans fluid, I saw what looked like cooler lines but didn't follow them forward. Anyone know if the '13 SS has a transmission cooler for the M6?
wakespeak is offline   Reply With Quote
Old 07-11-2013, 08:36 PM   #13
Est.July.4.1776
The pride of the CN
Est.July.4.1776's Avatar
Drives: '13 AGM 2SS/RS M6 & '70 Chevelle SS
"I've been working on the railroad, all mother f###ing day." ...and yeah, we hauled your Camaro.
Class 1 Freight Rail Conductor - Master Mason - NRA Life Member - Tennessee Squire - Firefighter I & II Certified
My other ride has 4,400+hp and corners like it's on rails... because it is.
Est.July.4.1776 is offline   Reply With Quote
Old 07-11-2013, 08:46 PM   #14
aggieguy13
aggieguy13's Avatar
and the brakes no?
