![]() Drives: 2010 2LT RS Camaro 2015 Colorado Join Date: Dec 2009
Led resistor help!
I installed vled's switchback turn sigs with supplied 50w 3ohm resistors.First using t-taps, still got quick flash. Decided it was connection , so soldered instead.Still got quick flash(normal flash for a few sec.)Just added 50w 6ohm resistors leaving others connected and still with the quick flash's..wth?
![]() ![]() Drives: 16 Camaro SS Join Date: Jul 2012
How did you wire the resistor in? The resistor has to be wired from the turn signal lead to ground. 6 Ohms are fine, a 3 Ohm resistor would draw twice as much power. 12/3=4amps
12/6=2amps.
Interior: Adrenaline Red. SS/2SS, M6, NPP, Sun Roof, 8" Nav. Black 5 Spoke Wheels.
One resistor wire to lead, the other to ground per instructions.I guess I'll check my solder job,while not pretty,seemed like good connections. Thanks
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 RJT Camaro LT2 RS auto shift Join Date: Dec 2011
Did you use 1 resistor per side or 1 for each tail light. I had to use 4 of 2ssrs load resistors [1 for each tail light] in order for mine to work ok.
Yes,one per each side front turn sig.,I also have one each side for my Techno. tail lamps.
#6 |
I had the same problem when I installed seq led turn signals lights. I wired 1 resistor to the main turn signal wire on each side. They would work part then go fast. I ordered 2 from 2ssr and they did the same thing. I asked 2ssr about it and he said you have to have 1 for each light. I ordered another set and connected them and have not had any more problems.
#7 | |
![]() Drives: 2014 Camaro LT RS in Red Hot Join Date: Aug 2013
Where did you mount your resistors?!? Mine got SOOO hot I was scared to mount them anywhere and just ended up putting my factory ones back in. Was using 1 3 Ohm 50Watt per bulb in rear. My IR temp gauge was reading over 350 Deg on the resistor! Got the resistors for 2ssrs. |
#8 | |
| Tags |
| resistors, switchbacks |
