Old 07-16-2013, 07:44 AM   #1
SmokedSS
Guest
Drives: 2011 2SS / RS A6
ADM FPCM
I have a question for those out there that have installed the ADM FPCM. I am running a ZL1 fuel pump, ZL1 3bar sensor and recently installed a cam and ID850's. I decided to add the ADM FPCM after what I read about it on the forum. I am also Supercharged. Before installing the FPCM fuel pressure maintained 57-59psi normal driving and would drop lb for lb of boost as I approached WOT(ex. 11psi boost = 45-46 psi fuel pressure) This is the main reason I added the FPCM but after adding it I am seeing the EXACT same thing happen. Do I have a problem or is this as good as it gets with my set-up? I am @ 650RWHP... Bad controller? Bad tune tables? Anyone having success with this @ this power level / set-up and how did you make it work? I am reading fuel psi from OB port via gage or dyno..
SmokedSS is offline   Reply With Quote
Old 07-16-2013, 08:02 AM   #2
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
Call Andy. Posting here is one thing, but I would call him. I use one myself and when the shop installed it my tuner (rhino79) said everything worked 100 percent...I'm only running the 62.5lb injectors with the vortech kit though.
-John S.
Old 07-16-2013, 08:21 AM   #3
2012REDSS
Drives: 2012 Camaro SS
The tune has to be written to use the new FPCM to the full potential. Andy can give the tuning specs to your tuner. Just call him he's a great guy to work with.
2012REDSS is offline   Reply With Quote
Old 07-16-2013, 08:21 AM   #4
ADM PERFORMANCE
Drives: Anything I want
Forum having problems- contact me directly please.
Send me your tune also.
Scan gauges are not as accurate as straight from fuel rail
ADM PERFORMANCE is offline   Reply With Quote
Old 07-16-2013, 08:40 AM   #5
SmokedSS
Guest
I will try and get Andy and my tuner hooked up. My tuner has tryed twice to get it and called Andy once. My question on post was not bashing the FPCM it is "do I have a problem?" Will this work with my setup? I am dropping to low 40's fuel pressure on the dyno reading through data logging not just from my gages. This concerns me.. I just want to correct it if it can be corrected or understand this is the best it will function with my setup?
Old 07-16-2013, 09:32 AM   #6
dan0617
dan0617's Avatar
Drives: 2011 Inferno Orange SS Convertible
It should pressure at like 63 psi. If tune tables are correct then you may need a BAP too.
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, ID850’s, ZL1 pump with MSD Voltage Booster, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. A million other supporting mods. Tuned by Ted.
dan0617 is offline   Reply With Quote
Old 07-16-2013, 09:35 AM   #7
SmokedSS
Guest
Re-word my question...
My setup.. Auto, Maggie @ 11.5 boost, Night Fury Cam, Zl1 fuel pump, ADM FPCM, Zl1 3bar sensor, ID850 injectors RWHP 652, RWTQ 675.
Question.. With the FPCM what fuel pressure can I expect to see normal driving and then @ WOT?
It may be doing its job.. I am just asking
thanks,
Old 07-16-2013, 11:20 AM   #8
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
Depends on how it is tuned. Could command 50 psi at idle and 63 psi WOT, depends. If the tune wasn't changed, could be 58 psi all the time.
Iam Broke is offline   Reply With Quote
Old 07-16-2013, 11:24 AM   #9
SmokedSS
Guest
I am @ 58 psi idle and 43-46 psi WOT... Is something wrong or is this as good as it gets with my set0up / RWHP?
Old 07-16-2013, 12:07 PM   #10
Synner
Drives: cars
Sounds like the tune isn't modified to use the new FPCM, stop going WOT until you get the tune fixed.
Old 07-16-2013, 12:29 PM   #11
SmokedSS
Guest
Is anyone out there running this rwhp (652) on this setup (ZL1 fuel pump, ADM FPCM 850 inj.) successfully? What is your fuel pressure @ WOT?
Old 07-16-2013, 12:31 PM   #12
swiftkart
swiftkart's Avatar
Drives: 2010 SS/RS LS3 M6
It has to be programmed by your tuner or someone, it's not a simply plug and play, after it's set to ADM's spec's it should be 58 psi normal driving and 68 to 70 psi WOT, then you subtract whatever boost you are running so roughly 58 psi at WOT for your 11.5 psi boost level, should never drop below 55 to 58 psi.
swiftkart is offline   Reply With Quote
Old 07-16-2013, 12:42 PM   #13
SmokedSS
Guest
I agree with what you are saying. That is what I read and it helped me make the decision to purchase this. I still have the 1 question because others have asked it and it has not been answered straight-up. Will / can this support my power /mod level and maintain this fuel pressure? I would be happy if it maintained 50psi!!
Old 07-16-2013, 12:48 PM   #14
grocerygetter
instigator
I was told the fpcm/zl1 pump combo was good to 650...I wonder if you are flirting with it's limits. I planned to stop at low 600s (since I'm an auto with converter, numbers show lower on a dyno because the converter eats up power) with my modding circus. lol
-John S.
