Old 07-17-2013, 08:44 PM   #1
lakersftbl69
lakersftbl69's Avatar
Drives: 2010 camaro ss
how many of you.........
how many of you are running 575-600 rwhp with out being forged and on a stock block with out issues. im really considering going FI and looking to do that power just looking to see how everyones car is holding up.
ordered dec 15 2008 picked up on june 8 2009.
upgrades kooks 1 7/8" LTH w/ deleted cats, corsa exhaust, hurst short throw shifter stage 3 comp cam, 3.91 gears ecs kit blower, meth injection, upgraded axles, drive shaft, McLeod rxt clutch, fully forged 416ci stroker all installed and dyno tuned by slowhawk performance in bridgewater ma.
lakersftbl69 is offline   Reply With Quote
Old 07-17-2013, 08:57 PM   #2
old motorhead
Drives: Maggie blown LS3 vette
650ish rwhp with TVS, bolt ons, mild blower cam, and a little over 9psi. Been running that way for over 4 years and 30K miles (vette M6 LS3). The key is plenty of fuel and a good tune. It also helps if you're not a dumb mullet hell bent on tearing stuff up
old motorhead is offline   Reply With Quote
Old 07-17-2013, 09:05 PM   #3
dan0617
dan0617's Avatar
Drives: 2011 Inferno Orange SS Convertible
I'm running 12 psi and a 100 shot on a bone stock L99 with headers. Should be 625 to 650 rwhp through the auto. It's all in the (Jannetty) tune to make it live. A good tuner will make that power feel like stock when not at WOT and make it live a long time.
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, ID850’s, ZL1 pump with MSD Voltage Booster, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. A million other supporting mods. Tuned by Ted.
dan0617 is offline   Reply With Quote
Old 07-17-2013, 09:07 PM   #4
Unreal
Drives: 2006 Z06
9-10psi, stock l99 AGP twin turbo, 650-680rwhp, 14k miles no issues. Now added heads/cam and makes more power, probably 750rwhp or so, no issues. 91 octane, no meth.
Nick
Corvette Z06 -1200ish rwhp
Old 07-17-2013, 09:31 PM   #5
calbert1999
Camaro SS Lover
calbert1999's Avatar
Drives: 2010 Camaro 2SS/RS Black IOM
Just a matter of time and all these bone stock engines will be busted up to bits.
calbert1999 is offline   Reply With Quote
Old 07-17-2013, 09:43 PM   #6
old motorhead
Or maybe, just maybe they will last a long time and give lots of enjoyment to the guys that can make it work. If mine shoots craps tomorrow, I'm calling it good. It just might last quite a bit longer too
Old 07-17-2013, 09:47 PM   #7
Unreal
Drives: 2006 Z06
Same can be said for a bone stock car.
Nick
Old 07-17-2013, 09:51 PM   #8
dan0617
dan0617's Avatar
True. And it's just a matter of time till all we own is a 8' x 3' piece of land and a rock with our name on it.
Old 07-17-2013, 09:54 PM   #9
Blackkaz04
Drives: 2006 Z06
this thread has been done....ALOT
Blackkaz04 is offline   Reply With Quote
Old 07-17-2013, 09:54 PM   #10
old motorhead
Attababy! That's it in a nutshell. If you live, paralyzed by the thought of your next potential failure.....not much of a life
Old 07-17-2013, 10:00 PM   #11
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
Originally Posted by old motorhead View Post
Attababy! That's it in a nutshell. If you live worried about your next failure.....not much of a life
Well said.....
I ran 600rwhp on the stock engine for 2 years and more 1/4 mile passes than I can count. I went with a forged short block and my original engine is still running fine in a drift car now.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000,
realcanuk is offline   Reply With Quote
Old 07-17-2013, 10:04 PM   #12
ZOOK
ZOOK's Avatar
Drives: 2010 2ss 6 speed
tvs 2300
Did the Street Brawler Package from Jannetty 2 years ago ..34k on the car and going strong ....I did the work and Ted did the remote tune..........A lot of it's in the tuner..
ZOOK is offline   Reply With Quote
Old 07-17-2013, 10:27 PM   #13
lakersftbl69
thanks guys for the info I appreciate it alot
Old 07-17-2013, 10:47 PM   #14
Slickcas
Drives: 12' 2SS/RS LS3 IBM
After lowering the boost a little I am at 624rwhp and the motor has not missed a beat. A BIG key is tune of corse but do not over rev. the thing. I seen a few LS motors that would have lasted a long time but there tard owner took it to 6800 every shift. A stock bottom end will only last so long at them RPMs.
Slickcas is offline   Reply With Quote
