Old 07-18-2013, 07:39 PM   #1
markmass
TRI-COUNTY CAMAROS
markmass's Avatar
Drives: 2SS/RS Oct 2009
For those with Hex Vents...
I have had these hex vents on for a few months, and absolutely love them. I also have the 'water deflection trays. Florida at the moment is constantly rain, Now while the trays do the job, the water will defect on to the block, belts etc, which is of course ok - however I'm pretty anal about water and where I don't want it to go so i thought about ways of taking the water away from the main components.
Home Depot, couple of brass fittings, some vinyl pipe and this should do the job.
The brass fittings (pictured) i cut most thread off, leaving about 1/8" just enough to screw into a 1/2" hole i made at the lowest point.
I also used epoxy to ensure the brass fitting is solid and doesn't leak.
Refitted the trays and ran a length of vinyl tubing to the front of the hood, above the rad, of course i may tinker with this, but seems to be a good place
I took a few of the push in fittings out and used a tie wrap through the hood cover to secure the tubing
i think $10 in total, plus i have about 8 foot of pipe left!
GET-TORQ custom CAM 223/243 LSA113, Full LS3 conversion, 3200 stall Multi-Disk TC from Circle-D, B&M Supercooler to cool that tranny down....1 7/8" Kooks Headers and High flowCats. MACH XL Catbacks. Eibach springs, R2C Performance CAI, powdercoated calipers, Footwell lighting in tune with dome lights, tints, ABL Lighting, ACS T3 ports and ACS Eagle T3 triple LED lighting kit. Heritage grill, Hex vents, ZL1 rockers, ZL1 Diffuser, Quad tips...the list keeps getting longer - whats next??
markmass is offline   Reply With Quote
Old 07-19-2013, 04:02 AM   #2
TRC-SS
700RWHP-650TQ
TRC-SS's Avatar
Drives: 2011 Forged LS3 Supercharged/Cammed
Great job!
View Build HERE>>>>>MY 2011 2SS/RS JOURNAL
TRC-SS is offline   Reply With Quote
Old 08-01-2013, 01:03 AM   #3
Lio Martinez
Drives: 2013 Camaro 2SS RS 1LE IMO Turbo
I really need to do this!!
Lio Martinez is offline   Reply With Quote
Old 08-01-2013, 01:19 AM   #4
LIM3
it's mind bottling..
LIM3's Avatar
Drives: SGM
Great idea
Old 08-01-2013, 05:15 AM   #5
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Smart move....I've been tracking where my water exits and so far ok, but I'll do this..... Steve is working on a quik disconnect splash tray as well. I'm in Florida too and made some plexi drop in covers to keep the tree crap out when blowing out...they work well, weighted them with stick in wheel weights..pics here...
http://www.camaro5.com/forums/showpo...0&postcount=76
Glen e is offline   Reply With Quote
Old 08-01-2013, 12:26 PM   #6
Aubrey64
Aubrey64's Avatar
Drives: 2010 Camaro LLT/RS
This is really cool! Nice job!
Aubrey64 is offline   Reply With Quote
Old 08-08-2013, 01:15 PM   #7
markmass
TRI-COUNTY CAMAROS
markmass's Avatar
Thanks all, Nice job Glen. I had thoughts about something like that, but now you have given me some inspiration!!
Cheers
Old 08-12-2013, 05:38 AM   #8
CamaroLB
SoCal HT5 COTW 12/16/2013
CamaroLB's Avatar
Drives: Burning B
Thats super cool! I would definitely need to do this before winter comes our way !!
CamaroLB is offline   Reply With Quote
Old 08-12-2013, 06:41 AM   #9
Steven13
Steven13's Avatar
Drives: 13' Black SS
dude thats awesome, but are the hex vents a cosmetic thing only?
Steven13 is offline   Reply With Quote
Old 08-12-2013, 03:56 PM   #10
markmass
TRI-COUNTY CAMAROS
markmass's Avatar
No - they are functional, and i think they look pretty cool . You do cut a hole in the hood and fit these. Primarily heat dissipation. After a run I can see the heat pouring through these things
Old 08-12-2013, 05:03 PM   #11
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Mark - Here's another mod I did today. I am having to take off my pans weekly, as where I live, smaller stuff gets by my screen and into the pan. My covers go on at night but I like the pans clean. The problem arises when you take off the pan and put it back. You kinda search for the thread to bolt into the vent and if you miss it, you can screw up the threads. That's long term a bad thing. So after discussing with Steve, I cut the head off a machine screw , and made it into threaded rod which now sticks down...made a slightly larger hole in pan, so it will punch thru and a rubber washer and nut complete the project. Now you never screw up the threads in the vent which is not easily fixable. Studs look like this:
the bolt is at lowes : M4 x 0.7 x 60mm & rubber washers and fender washers
nice thumbscrew here: http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Old 08-12-2013, 09:43 PM   #12
markmass
TRI-COUNTY CAMAROS
markmass's Avatar
Nice idea - like it. I have done that a few times trying to line the threads up!
Old 08-13-2013, 02:21 AM   #13
Blk-Ice
750HP of Twisted Reaper!
Blk-Ice's Avatar
Drives: Blk 2SS/Blk Carb Fibr NS-1 stripes
I Got this idea from a Club member of mine. I dont use the trays, i cut these and use them to close off my vents from the top when i use car washes with the high power sprayers. They work great and keep ALL water out.
Fear the LMR Twisted Reaper Brotherhood!
Blk-Ice is offline   Reply With Quote
Old 08-13-2013, 02:23 AM   #14
Blk-Ice
Blk-Ice's Avatar
