Old 07-22-2013, 12:35 AM   #1
Edge1
Drives: 2013 AGM 2SS/RS 1LE
Front tire sidewall crack
I remember about a bulletin regarding cracking tires with low temperature. These tires have not seen those temps but I found this crack on the front passenger tire while washing today. It has 5K miles on it and has never any curbs/objects. Should this be covered under warranty? It seems to me that it is defective.
Edge1 is offline   Reply With Quote
Old 07-22-2013, 01:29 AM   #2
Jc's1LE
Drives: 2015 SW 1LE BA NPP Recaros
do you check you psi? I would take that back to the dealer have them look at
Jc's1LE is offline   Reply With Quote
Old 07-22-2013, 02:53 AM   #3
schecter7
schecter7's Avatar
Drives: 2013 Black 2SS 1LE
Since you haven't hit anything, it looks like a manufacturing defect. It's definitely covered under warranty - see your dealer asap. I would not mess around with a cracked tire. Good luck.
schecter7 is offline   Reply With Quote
Old 07-22-2013, 09:32 AM   #4
gatekeeper750
Drives: 2013 Camaro SS 1LE Package
My driver side rear blew out on me on hwy 2 weeks ago with only 1660mi on them. Thank God for run flats!! Drove str8 the the dealership got out car and looked at tire...the was a crack in the wall where tire split open. Service guy try to say maybe I hit something on the hwy, but I'm thinking my frt tire would have hit it first!! Anyway, they replaced under warranty thru GY! So me all happy now!!! Good Luck with it but I'm sure they will take care of it!!
gatekeeper750 is offline   Reply With Quote
Old 07-22-2013, 10:29 AM   #5
joeybsyc
joeybsyc's Avatar
Drives: 2010 Aqua Blue Metallic 2SS
That doesn't look like a crack to me, there's even a chunk missing where the initial impact gouged the tire. Something obviously cut it.
joeybsyc is offline   Reply With Quote
Old 07-22-2013, 10:34 AM   #6
strych9
I'll be back...
strych9's Avatar
Drives: Subaru, HD Road Glide Special
I agree. It looks like something damaged the tire. Have your dealer look at it, and they'll make the call.
Bye bye, Bumblebee!
Old 07-22-2013, 10:41 AM   #7
tramtwo
tramtwo's Avatar
Drives: 2021 1LE
no runflats on these cars
tramtwo is offline   Reply With Quote
Old 07-22-2013, 10:55 AM   #8
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
When did they start putting run flats on 1LEs, or have you already changed tires?
The Bird is the word!
Old 07-22-2013, 11:39 AM   #9
tramtwo
tramtwo's Avatar
Drives: 2021 1LE
They havn't ...
Old 07-22-2013, 11:48 AM   #10
Angrybird 12
Originally Posted by tramtwo View Post
They havn't ...
I just wanted to see how he would explain it .... Usually when someone calls someone out on a BS post they never explain themselves or make something else up and end up digging a deeper hole.
Old 07-22-2013, 11:51 AM   #11
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
As stiff as these sidewalls are, I bet he did not even realize he had a flat at first. Until you turned the wheel, I bet you can go a long way in a straight line before you realize it. Doesn't the DIC warn of low tire pressure?
gajagfan is offline   Reply With Quote
Old 07-22-2013, 11:52 AM   #12
Angrybird 12
Yep.
Old 07-22-2013, 12:10 PM   #13
Fred 6528
Fred 6528's Avatar
Drives: 2011 ss
I have to agree with others that this tire has hit something. Look carefully and you can see the evidence of this. (1) scuff mark between the y and e on goodyear. (2) a second line scar going up and down thru the e on goodyear. (3) another scuff mark on the part that says owners, this even was erasing the letters until it puntured the tire. Good luck on getting the dealer to believe this tire has not hit something. Let us know the end results
Fred 6528 is offline   Reply With Quote
Old 07-22-2013, 07:05 PM   #14
Biv08SS
Biv08SS's Avatar
Drives: 2014 Z/28
I have a spot on my drivers side rear tire that looks odd to me and I KNOW for a fact that I haven't hit anything with mine (YET) it has 176 miles on her. I'll get a pic in just a bit for everyone to judge
Biv08SS is offline   Reply With Quote
