![]() Drives: 2012 ZL1 Camaro Join Date: Apr 2012
What is you Post Track Day Maintenance Routine?
I just had a fantastic experience taking my ZL1 to my very first HPDE event. I am just a rookie who wants to learn how to properly drive the ZL1 on the track, so the HPDE event held in my hometown by NASA was a great introduction where I could learn the proper skills and techniques. The ZL1 performed exceedingly well on the track.
Now my question... The Track Day is now over. For those of you who track your ZL1, can you share your post-track maintenance routine here on this thread. I've read the manuals and watched the videos, but I wanted to hear from you guys on your standard check lists after a great day on the track. Much appreciated! |
Diff service. Tire and brake inspection. Full paint decon and detail
Repeat as soon as possible.
Laus Deo
![]() Drives: 2013 Camaro ZL1 Join Date: May 2013
This could be either pre or post track day
Inspect or Change (depends how hard and hot you run your vehicle) Engine Oil and Filter Transmission Fluid Diff Fluid Brake Fluid Brake Pad and Rotors Tires Wheel Torque Also Check Seat Belt - safe working condition Lights - brake lights working Glass - no cracking Fluid leaks Wheel Bearing - no excess play Suspension component - bolts torque Steering - no excess play Battery - secured, corrosion, and charged Engine Belts - good working condition
LSA VR38DETT 4B11 2ZZ-GE-SC N55 B18C5 302
| Tags |
| maintenance, track |
