Old 07-25-2013, 01:57 AM   #1
Puladulaman
Drives: 2010 cyber gray SS/RS
Bolt on camaro what's my next step besides force induction
2010 SS 6M looking to get some more out of it and lower my 1/4 mile time not really looking to do sespenion work and don't know what would be the next step to get the most bang for the buck I been doing upgrades here and there and it helps when it's spaces apart I'm not a guy to drop 15 grand at one time but grand here and there doesn't make it so bad so trying to keep this time around $1000
Here's my total engine upgrades
MBRP catback exhaust kooks 1/78 headers vararam intake comp cam done by vector motorsports dyno tuned by breathless performance car put out 458rwhp
Other upgrades
Drive shaft shop 1000hp axles pfadt trailing arms eibach lowering springs nitto nt05sin the back nitto invos in the front
My thoughts on the next thing to do is either 3.91 gears or a 100shot even if there's a few smaller things that would help that would be fine once again I'm tryin to keep it around $1000 give or take a few bucks please any opinions would help hopefully people who's had experience with this problem thanks in advance
Puladulaman is offline   Reply With Quote
Old 07-25-2013, 02:59 AM   #2
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
Gears. I dont care for NOS so that is my opinon.
2010 Camaro SS LS3 - No Modz
376LS3 is offline   Reply With Quote
Old 07-25-2013, 03:26 AM   #3
Nightmare2012
come find out;)
Drives: stockish 2012 camaro ss
Under drive pulley,gears,a meizere electrical water pump would help with parasitic loss,upgrade clutch,port your heads (might be alil over 1000 though)
Nightmare2012 is offline   Reply With Quote
Old 07-25-2013, 03:49 AM   #4
62nalide
62nalide's Avatar
Drives: 2013 SS
Slicks for traction since you have 1000hp axles
62nalide is offline   Reply With Quote
Old 07-25-2013, 04:09 AM   #5
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Stickier tires and gears would be high on the list. Stiffer bushings will help with your launch and will greatly lessen wheel hop, which is murder on your drive train. Once you're sure that you've gotten the most of out your setup, add the juice.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 07-25-2013, 04:40 AM   #6
ZWA SS
BowtieBelle's SS
ZWA SS's Avatar
Drives: 2010 Camaro SS
Bushings and drag tires.
ZWA SS is offline   Reply With Quote
Old 07-25-2013, 06:16 AM   #7
SPCBA
Drives: pleather and Chiclets
coilovers bushing and the rest of the suspension. one piece drive line.
dont really know how you drive your car or what you drive it on.
SPCBA is offline   Reply With Quote
Old 07-25-2013, 10:23 AM   #8
Puladulaman
Oh yea believe I know all about wheel hop it's the devil ! Lol but since I put the trailing arms and axles car doesn't wheel hop at all anymore. And as far as tires go I'm not gunna change what's on there until I need new tires then get a DR. But I'm not really concerned about that much because I would like to do a track setup because I'm still running stock 20s but that's something down the road I'm just looking to get more power or power to the ground I.E gears but Suspension is something I'm just not worried about right now
3.91, bolt on, gears, nitrous, opinion
