Russ
Does the air scoop make a difference or not?
I did a search looking for info on the air scoop. I read that some people claim they make a difference while others say they couldn't tell any difference. I am considering this mod but only if I am sure it will make a difference. Is there any different sound with the air scoop? I know some people claimed the engine sounded much better with a CAI but I couldn't tell the difference in sound at all.
Does the air scoop make a difference in quickness, HP, etc? Is there any difference in sound with the air scoop? Please help me make a decision guys! Russ |
![]() ![]() ![]() ![]() ![]() Drives: 2012 SIM 2LT/1970 Camaro Join Date: Nov 2012
Search for Jannetty's 2nd CAI test. He had with/without scoop results that showed a definite improvement for most intakes with the scoop.
Edit: Here it is: http://www.camaro5.com/forums/showthread.php?t=107002
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting |
At super Chevy I was able to cut my best time to date. Cut three tenths off and the only difference in mods were TSW Nurbergrings with Nitto Invo's (and I cut worse 60's with them) and a scoop and washer bottle relocate. So I would say it helps. It's only gonna help on the top end though...as more air is moving over the car more air gets pulled into the scoop. Soooo off the line there won't be any change.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 SS Join Date: May 2013
Yes it makes a difference but you won't feel the gains but you will see it in the track. IDK about most people but 2rwhp 5rwhp is not going to throw you back into your seat.
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
I've added a scoop and I have not seen any clear cut gains yet. We'll see in the fall. No increase in noise.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
#6 |
![]() Drives: 2021 2SS 1le Shock Join Date: Feb 2011
I have the race scoop and washer bottle relocate from JRE installed. At idle hold a paper towel in from of the scoop and it'll suck the paper towel in. Quality set up! I felt no difference in power, maybe a slight increase in sound. Moving the washer bottle out of the box and adding the scoop cant help but believe the car gets much better air flow and breathes easier.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '69 SS Convertible Join Date: May 2009
Go look in your engine compartment and imagine removing your washer bottle and see how much air is being blocked by it being there. There is no way it can't help. Again like others have said you're not going to be thrown back in your seat but it's going to help.
Here, found my pics.
Build Journal ![]() |
#8 |
![]() Drives: 2010 2SS/RS Join Date: Jan 2010
Was it an easy install?
#9 |
Wasn't that hard at all IMO. Take the driver's wheel off, about 5 or 6 pop-in locks (come out with a flat blade screwdriver) to remove the inner fender well and you have all the room you need.
#10 |
![]() Drives: white 2010 ss and 2011 6.2 silvy Join Date: Jan 2011
I cant see the scoop making a real difference, but the washer bottle blocking all the airflow seems to be a real problem. I bought a 10 dollar universal washer tank,relocated it to the trunk and got rid of the factory washer bottle. I also trimmed the plastic behind the grille opening like the scoop has you do to get better airflow into the filter housing. I saved some cash doing it this way. I might be better off with a scoop but who knows?
2010 RS2SS, XS POWER HEADERS AND FULL EXHAUST, ROTOFAB COLD AIR AND ENGINE COVERS, MSD PLUG WIRES. PFADT DROP SPRINGS, SPORT SWAY BARS, TRAILING ARMS, TOE LINKS. HURST SHIFTER, BILLET PEDALS.
BLACKOUT TAIL PANEL, TINTED TAIL LIGHTS, MAIL SLOT BLACKOUT, WHITE BOWTIES |
#11 |
![]() Drives: 2012 Camaro SS Join Date: Oct 2011
I cut two tenths off my time when I installed the scoop at the track. I had the rotofab CAI then. Its worth it for 50 bucks.
#12 |
Where did you find it for $50?
#13 |
750HP of Twisted Reaper!
Drives: Blk 2SS/Blk Carb Fibr NS-1 stripes Join Date: Oct 2010
I thought the CAI gave it a deeper sound back when i did it, long before all my other mods. As for the scoop/washer bottle relocation, it was easy to install and it definately felt like it made a difference via my BUTT DYNO!
Fear the LMR Twisted Reaper Brotherhood!
#14 | |
Philippians 4:13
Drives: SLP Supercharged LS3 Join Date: Aug 2009
![]() I installed this one on mine and for the money and the ease instalation I felt it was well worth it. The stock washer bottle really blocks a considerable abount of air flow. Here are the pics from my install after I made the cut: Here is looking down into the CAI: A lot of people suggest using a dremil rotory tool to do this job which will work, but I found this to be even better and a much much cleaner cut. ![]()
