Old 08-01-2013, 07:08 PM   #1
Matt @ FSP
Matt @ FSP's Avatar
Drives: 2011 Camaro SS
*Pics* Why you should do a Solid Isolator Coupler...
9400 miles...
Matt @ FSP is offline   Reply With Quote
Old 08-01-2013, 07:40 PM   #2
PNYSLAR
Summit White 2012 ZL1 M6
PNYSLAR's Avatar
Drives: 2010 BLACK 2SS/RS M6 Delvd 8/24/9
mayby I'm being obtuse.. But what are looking at besides the front of the supercharger?
2012 Summit White ZL1 Manual 6sp Blk 10 spoke, "Thanks Champion Chevrolet" delivered 6/9/2012 #1588
PNYSLAR is offline   Reply With Quote
Old 08-01-2013, 07:44 PM   #3
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
See how the spring in the right side of pic4 has rubbed into the shaft in pic 3. That should be smooth. That's the rattle you hear from the ZL's
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 08-01-2013, 07:58 PM   #4
LS1 Fun
Drives: 2013 ZL1
At first I was like WTF but now I see it. Pic 3 shows the damage the best.
I have 8200 miles on mine and it's stock...
1974 Cadillac Coupe DeVille
2002 Camaro Z28 A4 | 10.80 @ 131 | 383ci, D1SC, 4L80E, 9"
2013 Camaro ZL1 A6 | 12.62 @ 113 | Stock *SOLD
2017 Lexus GS350F
LS1 Fun is offline   Reply With Quote
Old 08-01-2013, 07:58 PM   #5
Modern07
Mid-Florida Camaro Club
Modern07's Avatar
Drives: 2019 ZL1 on Order
And to think I didn't think mine rattled haha!
I must be deaf or something!!
Still replaced now
Modern07 is offline   Reply With Quote
Old 08-01-2013, 08:01 PM   #6
bumblebeecamaro
Car Lover By Nature
Drives: 2016 Hyper Blue Metallic SS
that is insane. I can't believe GM continues to allow this shotty design in such a high end car like the ZL1.
I want to replace my coupler so bad but I'm terrified of losing my warranty on my S/Cer.
bumblebeecamaro is offline   Reply With Quote
Old 08-01-2013, 08:03 PM   #7
joes407
joes407's Avatar
Drives: 2014 ZL1m6 red hot #569
Still replaced now
is that yours phil?
joes407 is offline   Reply With Quote
Old 08-01-2013, 08:04 PM   #8
Modern07
Modern07's Avatar
Originally Posted by joes407 View Post
is that yours phil?
Yes
Removed today
Bad isn't it!
Old 08-01-2013, 08:15 PM   #9
joes407
joes407's Avatar
riddle me this matt. the wear shown is 9k miles so does that wear lessen or subside as the car breaks in or will the wear proceed at the current rate through the mileage of the car thus wearing through in xxx miles?
Old 08-01-2013, 08:19 PM   #10
joes407
joes407's Avatar
Yes
Removed today
Bad isn't it!
it may look worse than it actually is. we have to remember g.m is standing behind this design for 100k miles. that would be roughly 1900 superchargers in '12 and 9k superchargers put on '13's so far. that would be serious cost to warranty all of them if they are all wearing at this rate. my thought is the initial wear happens quickly due to the break in but then subsides to a tolerable wear rate soon after. at that point some rattle and some don't.
Old 08-01-2013, 08:24 PM   #11
Matt @ FSP
Matt @ FSP's Avatar
Joe I cannot give you an accurate answer on this as we have not done conditional testing on any of this.
I can say that I have seen 100+ LSA motors apart. Among those for example; a 140 mile ZR1 that was fine, 1500 mile CTS-V that was worse than this, and a 40k CTS-V that was fine... Out of all the ones that were taken apart, I'd say 80%+ of the ones that we take off (Its part of our package so we always change these) have impacted the shaft from the spring. In this case we also deburr all 6 pins because the breakdown of the isolator starts elongating some of the bolt holes and the pins get a bit scored.
Old 08-01-2013, 08:25 PM   #12
joes407
joes407's Avatar
Yes
Removed today
Bad isn't it!
let me know when pick up time is for your car. id love to get an eye on matts shop if you need a ride out & im sure we'd be at high ticket risk on way back though
Old 08-01-2013, 08:26 PM   #13
Matt @ FSP
Matt @ FSP's Avatar
Still replaced now
The only rattle is the loose nut behind the steering wheel...
Thanks willhe for the clarification, I was trying to be too slick in just posting pictures and letting everyone take a look.. The other side of the shaft 180* out from that has very few marks on it, so I'd contribute that to run-out while the isolator/tensioner was breaking down.
Old 08-01-2013, 08:28 PM   #14
joes407
joes407's Avatar
so in simplified terms youre saying the wear is unpredictable and varies supercharger to supercharger but that the solid coupler hasn't been around long enough to assess whether or not it might cause a negative effect down the road or less than 100k mile life expectancy?
