Drives: LT Join Date: Aug 2013
Put wrong type of fuel, CEL is on
put the wrong type of fuel in my car now the check engine light is on what must i do?!
This is not a Troll post !! and the fuel i put on my LT was E85 Last edited by Dumbman12; 08-02-2013 at 02:53 PM. |
What fuel did you put in?
2010 2LT CGM Auto
Vararam CAI - Modern Muscle Ported Throttle Body - Vmax Black Iceolator - Custom Exhaust - Magnaflow Res X 11386 - 2.5" Pipe from X on Back - Magnaflow Round Mufflers 10416 - Lime Green Hood Spears - Lime Green Gill Stripes - SJM AutoProd Sequential Turn Signals - SJM AutoProd Always On DRL Fog Lights |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 GT350 Join Date: Nov 2011
Did you put a lower octane in? I thought the V6 could use 87 without issue?
I would check the code, make sure its just a knocking code due to low octane, then perhaps consider picking up an octane booster to raise the octane level?
Off to the Dark Side
I'll be back...
Drives: Subaru, HD Road Glide Special Join Date: Apr 2012
The only fuel that would trigger the light is E85 or maybe E15. It won't run on that well at all. You're going to need to have that fuel removed from your tank, refill with correct fuel, then clear the codes.
Bye bye, Bumblebee!
#5 | |
Mother of PWA Babies
Drives: 2011 RJT 2LT/RS Join Date: Apr 2011
I been running 87 for over 2 years. No issues here. I am wonder what kind of gas the OP put in the tank to cause issues. Diesel???
#6 |
Austin LT
Drives: 1LT - Airaid,JBA Axleback,VMax PTB Join Date: Jun 2009
The only "wrong" fuel for an LT is E85 or diesel......
#7 |
![]() ![]() ![]() ![]() Drives: Alot Join Date: Mar 2013
Diesel?
#8 |
If its diesel...damn...gonna be an expensive fix.
#9 |
OP, We need more information if we are going to help you.
#10 |
The smell and the foaming should have given that one away.
#11 |
![]() ![]() ![]() Drives: 2014 2SS/RS Convertible Join Date: Jun 2013
Maybe OP just didn't get the gas cap tight. That can set off the check engine light.
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro IBM 2LT/RS M6 Join Date: Sep 2009
#13 |
With no info from the OP we could speculate all day...
And probably will!
#14 | |
Good to know.
