Old 08-03-2013, 12:42 PM   #1
Elementkng20
HTCC: canthonyIOM27
Elementkng20's Avatar
Drives: 2012 IOM 1LT/V6/A6
A6 Shift points?
What's the normal/standard shift point rpm at WOT. I wanted to see the acceleration at WOT. I was in D and I noticed I hit almost 5500-6000 before it shifted into 2nd? Since it went that high I flicked the tapshift to shift down.
I'm sure it's normal. In previous cars I would never really open at WOT, if I did it was rare so when I actually noticed it in the Camaro I'm not too sure.
It's a 2012 1LT w/ 19k on it.
2012 IOM CAMARO V6/A6
Performance
K&N CAI
MRT V2 w/ 4" Magnaflow tips
Visual
Blacked out emblems, rear & bezels
Plasti dipped SS wheels
Tint 30% front; 5% rear
Matte black hood spears/side gills
Color matched interior accents
Elementkng20 is offline   Reply With Quote
Old 08-03-2013, 01:03 PM   #2
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
Don't you mean you shifted up? But yeah, in S mode it shifts between 5-6k for me.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 08-03-2013, 01:06 PM   #3
Elementkng20
HTCC: canthonyIOM27
Yeah shifted up to 2nd. My bad (shame on me, I drove a manual before this one lol)
I was in D but I was at WOT. Should it be the same even in D? I feel like that is high. I'm not to rpm savvy however.
Performance
K&N CAI
Visual
Old 08-03-2013, 01:26 PM   #4
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
In "D" the trans starts in 2nd gear, so at WOT it would have shifted to 3rd. In "S" the trans starts in 1st gear and shifts accordingly.
Old 08-03-2013, 01:35 PM   #5
Elementkng20
HTCC: canthonyIOM27
So is everything normal I assume for being D? Does that seem right?
Performance
K&N CAI
Visual
Old 08-03-2013, 01:37 PM   #6
All Star
I'm an Engineer
All Star's Avatar
Drives: 2019 Camaro 1SS 1LE
Send a message via AIM to All Star
Redline. It's always redline.
All Star is offline   Reply With Quote
Old 08-03-2013, 01:46 PM   #7
Elementkng20
HTCC: canthonyIOM27
I didn't hit the redline, but I was just like, "D" took me to 5500-6000 at WOT before it shifted...
not sure if that's normal, or a trans issue?
No other issues though, no hard shifts, no sounds, noises or anything. I might just be looking into it too much.
Performance
K&N CAI
Visual
Old 08-03-2013, 02:00 PM   #8
lincoln361
lincoln361's Avatar
Drives: 2011 Camaro SS/RS
Try doing it while you are in sport mode "S". When it is in sport mode I am pretty sure it will shift automatically when it redlines. When it is in sport mode the gears will shift much harder by itself rather than it would in "D". Good luck.
SLP TVS 2300- 1 7/8 LG Headers- RDS NX Plate- 75 Shot- No Cats- SLP Loudmouth 2- NW102- 3.8 Pulley- OD Cog drive-12lbs boost-FIC 80# injectors-ZL1 Fuel Pump- RotoFab CAI- Apex CAI Scoop- Pat G Tune- Weld RTS drag pack- BMR Trailing Arms- BMR 1'' Drop Springs-BMR Lower Control Arms- BMR Toe Rods- BMR Rear Cradle Bushings- BMR Upper Control Arm Bushings- BMR Extreme Anti- Rollbar- Hotchkis Subframe Brace- Prosport Evo Boost & F/A Ratio
lincoln361 is offline   Reply With Quote
Old 08-03-2013, 02:02 PM   #9
SlingShot
SlingShot's Avatar
Your shift points in "D" are normal, no worries there...
Old 08-03-2013, 02:07 PM   #10
Elementkng20
HTCC: canthonyIOM27
Thanks. Normally I don't push the rpms, but I figured I'd see what it can do. Once I noticed I was getting to almost 6000 in "D" I hit the tapshift.
Performance
K&N CAI
Visual
Old 08-03-2013, 02:21 PM   #11
jasonfichter
jasonfichter's Avatar
Drives: 2017 A10 ZL1
when i put my car into sport mode it shifts just before the red line at WOT
jasonfichter is offline   Reply With Quote
Old 08-03-2013, 03:33 PM   #12
Dizzy82
Dizzy82's Avatar
I learn something new everyday.
Old 08-03-2013, 04:32 PM   #13
tonyko1
Banned
Drives: 2012 Camaro 2SS/RS Convertible, IBM
Yeah, try going to "S" mode right from a standstill and hit the gas in first and let off....you want to talk about a roller coaster ride of putting you back in your seat, ha, it is awesome.
tonyko1 is offline   Reply With Quote
Old 08-03-2013, 10:11 PM   #14
Austin45
The Logistician
Austin45's Avatar
Drives: 2012 LFX 45th Anniversary
In D at WOT it gets pretty high. I know, I do it every time I drive it
Austin45 is offline   Reply With Quote
