Old 08-04-2013, 06:33 PM   #1
knitetrain05
Drives: 2012 Camaro SS 45th Anniversary Edi
SEAFOAM would you put it in oil?
I got this thing about additive's. Things to clean injectors added into the gas tank, I think that's OK. BUT, additives to the engine oil to clean sludge off of parts in the motor... That scares me. I feel these things to some extent lessen the lubricating properties of oil.
Case in point, I have a 2012 camaro SS 45th with 2538 miles on it. I do not see myself adding a catch can. I have once used seafoam in the gas tank at 2500 miles. I would be real hesitant to add this to the engine oil for fear of some small degree of loss of lubrication.
The directions on the can of seafoam say its ok to add to oil to keep the motor clean and free of sludge and that it can be added every 2000 to 5000 miles for a clean engine.
Well what's your personal opinion or real life experience with this added to oil??
knitetrain05 is offline   Reply With Quote
Old 08-04-2013, 06:36 PM   #2
bkdamon
bkdamon's Avatar
Drives: Rally Yellow 2012 1LT
bkdamon is offline   Reply With Quote
Old 08-04-2013, 06:42 PM   #3
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
Don't put anything in your car other than gas and oil....no additives...it shouldn't need any..most gas has additives t o keep the fuel system clean....never put anything in the oil...it too has all your engine needs....most of the shelf type additives give false hope of a miracle ....high mileage cars hoping for a new engine in a bottle...ain't happening
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 08-04-2013, 06:43 PM   #4
knitetrain05
Boy, This popcorn is good. Guess nobody knows what seafoam is...
Old 08-04-2013, 06:44 PM   #5
knitetrain05
Thank you
Old 08-04-2013, 06:46 PM   #6
RollaMo
RollaMo's Avatar
Drives: 2017 2SS
How much sludge do you think your 2500 mile car really has?
There is absolutely no need for any kind of oil additives on a new car.
1996 Corvette - LT4
2017 Camaro 2SS
2019 GMC Sierra 2500 HD
2015 Harley Davidson Ultra Limited
RollaMo is offline   Reply With Quote
Old 08-04-2013, 06:53 PM   #7
RolltideSS
RolltideSS's Avatar
Drives: 2018 SS 1LE
I know what seafoam is and I personally wouldn't add it to my oil as I don't know for sure that it wouldn't reduce it's ability to work. That said when I do the ls3 conversion and cam upgrade I will be adding a catch can
RolltideSS is offline   Reply With Quote
Old 08-04-2013, 06:56 PM   #8
King Nothing
Turning wrenches
King Nothing's Avatar
Drives: 2011 Camaro SS By Berger 11BC21
In a car with over 100k yeah put it in the fuel tank and some in the brake booster line, I've done it and it helped clean the insides out in my 2000 LS1. In a car with less than 3k???? No lol you don't have enough wear on the engine to need seafoam, injector cleaner from chevron yeah but not seafoam
King Nothing is offline   Reply With Quote
Old 08-04-2013, 07:07 PM   #9
rich3fan
What's this button do?
rich3fan's Avatar
Drives: 2019 Black 2SS
I used it in my 2000 Firebird Formula at about 80K miles. Only left it in for about 500 miles then had the oil changed during a service visit at my dealer. My SA came to me and said a whole lot of sludge came out with the oil. Guess it worked.
2019 Black & Red & Silver 2SS - Bone Stock
rich3fan is offline   Reply With Quote
Old 08-05-2013, 08:29 AM   #10
tonyko1
Banned
Drives: 2012 Camaro 2SS/RS Convertible, IBM
Perfectly stated!
tonyko1 is offline   Reply With Quote
Old 08-10-2013, 02:47 AM   #11
Lemmy
Drives: 2010 GT500
Use high quality synthetic oils and name brand gasoline. You might, MIGHT, want to put some Marvel Mystery Oil in the gas at 100K, but do not put anything in your oil. You should have no sludge at this point in your engine's life anyway. Seafoam is more harsh than Marvel. Don't do it.
Lemmy is offline   Reply With Quote
Old 06-07-2018, 12:46 PM   #12
Kelli2011BadToTheBone2SS
Kelli2011BadToTheBone2SS's Avatar
Drives: 2011 2SS 444 Horse Power
Hi RollaMo
I have a 2011 2SS that I bought in 2016, after my first oil change from a Chevy dealer it ticks when I start it and runs hotter (looking at the tac) someone told me I should use Marvel Mystery oil in the engine, my beast now has 41,500 miles on what do you think? my 1st car at 16 was a 1968 SS with a 327 corvette engine in it, i learned a lot about engines growing up, and i am telling you that the oil isn't thick enough, i bought my car from (of all places) a Dodge dealership and it ran like the awesome Beast it is until my first oil change and they will not listen to me at the chevy dealerships because i believe 1. i am a female and 2. i am a blonde .... i called chevy's corporate office and he is like please do not take it back to Dodge, so now i am on my 3rd Chevy dealership and my car still TICKS!!!!!! wtf H E L P !!!!!
Kelli Jayne
Kelli2011BadToTheBone2SS is offline   Reply With Quote
Old 06-08-2018, 07:46 AM   #13
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
Don't put Marvel Mystery Oil in your car!!! What viscosity did the dealership put in and did they put enough in? Have you checked the dipstick? What does it say?
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 06-08-2018, 04:20 PM   #14
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
OP, we can argue the merits or pitfalls of Seafoam all day. I have used it in the past on a 100K mile plus Duramax with inconclusive results. Not bad, not great, just not sure. You have a 6 year old motor with 2500 miles on it. Why would you even think you need that type of internal motor cleaning? That motor is barely broken in. How many oil changes does the motor have under it? For a low mileage motor like that, I would be more concerned about leaving used oil inside for long periods of time without having it get up to temp to burn off moisture.
Personally, I wouldn't waste the time or money on an additive.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
