Old 08-04-2013, 08:11 PM   #1
Mb6000
Mb6000's Avatar
Drives: 2011 Camaro 2SS/RS LS3
2" TSP Headers Rubbing
I just installed my 2" TSP Headers and they're rubbing on the steering u-joint when I turn. Also the 2nd spark plug boot on the driver side touches. Anyone else have this problem? Otherwise I'm very happy. The car sounds awesome and can feel the power difference.
'11 Camaro 2SS/RS LS3 M6| Black on Black| BMR Strut Brace| P&P Throttle Body| Cold Air Inductions Black CAI| 2" TSP LT Headers| Cat-Back Exhaust| Hurst Line Lock| Night Fury Cam| Brian Tooley Valvetrain| Melling 10296| C5R chain| Comp Cam rocker kit| 3.91 1LE Gear Kit| MPD1 Z Force Hood| BMR Lowering Springs| 480hp/454tq
Mb6000 is offline   Reply With Quote
Old 08-04-2013, 08:59 PM   #2
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
No, the spark plug did touch on my cousin when I installed them on my cousins car. So I just went to a place that sells MSD plug wires, installed them and bent the connector (you can do that with MSD's. if your not happy I'm sure if you call TSP they'll set you straight.
Old 08-04-2013, 10:07 PM   #3
Khmero215
Khmero215's Avatar
Drives: Victory Red 2SS
yea, I'm having the same issue. But I only feel the rub on right turns
Khmero215 is offline   Reply With Quote
Old 08-04-2013, 10:37 PM   #4
blake-b
blake-b's Avatar
Drives: 2009 ZR1
I don't have TSP headers but my 2" headers also rubbed on the steering shaft but only when turning. The easiest fix is to take the header off and dimple it with a socket (socket turned on the side). You will not be able to see the dimple and it will not hurt the flow at all.
Your other re courses are to live with it or loosen the engine mounts and see if you can slide it towards the passenger side any. I dimpled mine and another time I had them off, I noticed they rubbed the passenger side frame rail just slightly so I dimpled it there too.
I understand people may not like the idea of something not fitting correctly out of the box and how some people may not like the idea of dimpling their headers. I honestly forget mine are dimpled until I see threads like these.
My advice it to dimple it and be done with it as that will be your least amount of downtime. Otherwise, you might get caught up in sending headers back and forth in order to get them right. I honestly don't see how that would do anyone any good because I am sure they are all made in the same jig. I suppose the company could dimple them or possibly do a hand weld job on the offending tube to clearance it, but again, dimpling it yourself is the fastest, easiest way to do it.
Old 08-04-2013, 10:45 PM   #5
Mb6000
Mb6000's Avatar
That's when I feel it too. I've tried adjusting the steering u-joint and still rubs
