Old 08-11-2013, 12:47 PM   #1
Nemax
Nemax's Avatar
Drives: 2012 Camaro 1LT/RS
ZL1 door ABL
I recently installed ZL1 door panels with abl on my 1LT. I used the harness from gen5diy and tapped into the switches on the door. The problem is even at brightest setting on the dim switch you can barely see the blue lights.
I read somewhere that the zl1 abl is dimmer than the normal abl lights is this true? Is the light tube aimed the wrong way, whats the right way? Can I install a stronger led with the same color as oem blue? Lastly connect the wire to something else than the door switches, (speaker?)
Would really appreciate any answers / ideas you guys would have.
Thanks
Nemax is offline   Reply With Quote
Old 08-11-2013, 03:25 PM   #2
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
The volts that the LED"s uses to to go to full power is only 3.6V, at the switch to power the light in it is 12V, so there is full power there, in the LED is a resister that brings the the 12v down to the needed 3.6V, have you looked at a ZL1 to see if it less light? one more thing you can try is adding a second LED to the other side of the pipe.
Old 08-11-2013, 05:25 PM   #3
Nemax
Nemax's Avatar
Thanks ofer, I just put in an order for 2 oem abl leds and splitters from your store.
Old 08-11-2013, 08:38 PM   #4
G-Oil Guy
Where am I?
G-Oil Guy's Avatar
Drives: Zoe the ZL1, 2012 Frontier
I have been told that there is some tape over the light pipe on the ZL1 that makes them dimmer. It doesn't seem to be an LED problem it's something that GM appears to have done on purpose. I read this somewhere on C5 but god help me I can't find it now.
I plan on swapping my ABL to orange to match my car. When I do I will look at my panel to see if there is something hindering the light.
FOR SALE: 2013 ZL1 Message me if interested
G-Oil Guy is offline   Reply With Quote
Old 08-11-2013, 09:33 PM   #5
2SSRS@Gen5diy
If you find it ones more post it i have never heard of this and 5 weeks ago had a set of the ZL1 door panles and did not see it on there, now there is some tape over the end of the panle but its been there from the start of the GEN 5 Camaro.
Old 08-11-2013, 09:41 PM   #6
G-Oil Guy
Where am I?
G-Oil Guy's Avatar
I was able to find it but I can't link it since I'm mobile. However if you search "#271 needs a little help" you'll find it.
That being said: if I swap over to stock orange (or red as it really is) will it still be dim? If so why is it dimmer on the ZL1s then the rest of the gen5s?
Old 08-11-2013, 09:55 PM   #7
Nemax
Nemax's Avatar
Here is the link: http://www.camaro5.com/forums/showthread.php?t=240370
Old 08-11-2013, 10:10 PM   #8
G-Oil Guy
Where am I?
G-Oil Guy's Avatar
Originally Posted by Nemax View Post
Thanks man!
I can't wait for my internet to be hooked up at my new place.
Old 08-11-2013, 11:07 PM   #9
Azzkker
Azzkker's Avatar
Drives: 2013 AGM ZL1, 99 z28, 89 iroc-z
its because there is black paint misted over the panel which acts as a light diffuser. Sand that off and it would be brighter.
Azzkker is offline   Reply With Quote
Old 08-12-2013, 03:44 PM   #10
Nemax
Nemax's Avatar
Thanks for all your help. I bought extra abl leds aswell as sand paper to remove the misted paint. Ill let you know how it goes.
Old 08-12-2013, 07:49 PM   #11
2SSRS@Gen5diy
I have a door panel out of a dusk car and its not as bright will take it apart in the AM and see what will work.
Old 08-12-2013, 09:11 PM   #12
G-Oil Guy
Where am I?
G-Oil Guy's Avatar
What grit are you using?
Old 08-13-2013, 05:17 PM   #13
Nemax
Nemax's Avatar
400 Super Fine from HomeDepot.
Old 08-15-2013, 11:00 PM   #14
Nemax
Nemax's Avatar
Hey again.
I have removed the door panel but what part of the panel do i need to sand the paint off? Or do i need to remove the center panel from the hole door panel and work on a side not seen on the pictures below.
The first 4 pics is with the light tube and 3 after without
