Old 08-12-2013, 12:36 AM   #1
BowenSS1
BowenSS1's Avatar
Drives: She totaled it!
need help finding a great wideband
I need help finding a real good ,fast reading wideband any suggestions?my buddy is going to tune it he said get a innovate lc1 and any gauge. Is the prosport wideband worth it?
I am upgrading my fuel system to zl1 pump, adm fpcm,id850's. Are you able to read wideband thru hp tuners?is that really needed ? I am a newbie when it comes to this what is everyone forced induction running thanks
BowenSS1 is offline   Reply With Quote
Old 08-12-2013, 08:22 AM   #2
white ZL1
Drives: none
NGK AFX with the NTK sensor, hands down.
Log it through HP Tuners and tune away.
white ZL1 is offline   Reply With Quote
Old 08-12-2013, 03:29 PM   #3
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
NGK is the most preferred. I had an Innovate LC-1 for a while, replaced it with an Autometer Cobalt Lambda gauge & Bosch sensor in an SLP column pod mount. I use the analog output for logging & tuning into HPT Pro but it's nice to have the visual at all times on the column of my actual lambda.
Edit: You need the Pro version to interface the WB properly or you can rig it in through the A/C pressure input via the ECU into the std version after modifying the tune to ignore the A/C pressure for the compressor, ect.
Iam Broke is offline   Reply With Quote
