Old 07-07-2009, 04:20 PM   #1
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
Squeal upon LS3 start up?
I'm at 220 miles today. I went out to the car to grab some lunch. Started it up and there was a high pitched squeal that was heard. After I slapped the throttle it got faster and louder and then it went away. Went to lunch, when I came back out to my car after it sat for about an hour, the same noise occured. I have a LS3 with a manual trans.
Anybody else getting this?
Old 07-07-2009, 04:21 PM   #2
Lucky SOB
Drives: 2010 Camaro 2SS/RS
That's interesting... Did you look at your serp. belt?
Lucky SOB is offline   Reply With Quote
Old 07-07-2009, 04:23 PM   #3
gtjacket
2G1FT1EW0A9118618
gtjacket's Avatar
Drives: 2010 Camaro 2SS Black/IOM M6
Definitely sounds like the serp belt needs to be tightened. Go to the dealer and have them check it. Should not take but a few minutes for them to do this.
1100, Preliminary order accepted 12/5
2000, Order accepted by GM 05/05
3000, Order accepted by production control 05/05
3400, Order broadcast 6/4
3800, Order produced 6/15
4000, Available to ship 6/16
4104, Bailment Invoice
4200, Shipped 6/19
6000, Delivered to the customer 6/25
2SS/RS BLK M6 GFX IOM interior
gtjacket is offline   Reply With Quote
Old 07-07-2009, 04:32 PM   #4
ffrcobra_65
Definitely the serpentine belt. The belt tensioner may not be doing its job..it is supposed to keep the belt at the correct tension as the belt naturally loosens over time. Or the belt itself is bad or glazed over. Or one of the pulleys is misaligned.
Here is what you can do to confirm it...spray or drop water on the belt while engine is running (be careful not to get any part of your body or clothing caught while you do this), the high pitch sound will even get louder and last longer until the water dissipates. If this happens, you know it is belt or tension related.
Don't use belt dressing to try to fix the squeal. Serp belts don't like belt dressing too much and actually makes them squel louder and longer, not to mention the dressing getting flung all over the place. Take it to the dealer, it is an easy fix.
Goodluck.
Old 07-07-2009, 04:37 PM   #5
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
That's what I thought as well. I'll swing by there on my way home.
Old 07-07-2009, 04:44 PM   #6
Vash
Drives: 00 Blazer
It has an automatic tensioner. Could be some oil or cleaner got on the belt. Probably just needs to be wiped down and driven a bit. But never hurts to let the tech look at it.
Old 07-07-2009, 09:00 PM   #7
THE EVIL TW1N
Banned
Drives: 2003 Cobra Convertible
+1
but it could also be the tensioner.
THE EVIL TW1N is offline   Reply With Quote
Old 07-09-2009, 04:34 AM   #8
BDA
Drives: GMC Acadia, F250
tensioner story
I once bought a chevy suburban for $10 because of a bad tensioner
- kept spitting the belt and overheating - dealer changed all accessories on the front of the engine including the tensioner ($4,000) - but put the same OLD pulley back on the NEW tensioner
$15 pulley - good as new
Highjack over
BDA is offline   Reply With Quote
Old 07-09-2009, 07:43 AM   #9
RoyalKev
Drives: 2010 Camaro SS
Maybe some installed a supercharger with out you noticing.
Sike its definitly the belt.
RoyalKev is offline   Reply With Quote
Old 07-09-2009, 07:47 AM   #10
canadian ss
Psycho on day pass
canadian ss's Avatar
Drives: 2010 yellow 1ss m6 -GM tech
Dam cat.
canadian ss is offline   Reply With Quote
Old 07-09-2009, 07:50 AM   #11
UncleBenny
UncleBenny's Avatar
Drives: 2009 G8 GT
My G8 squeals on start up, I tell people its the supercharger haha. All the G8's seem to do it though, people on forums say its the alternator. I believe the GXP's do it as well, and they have the LS3 in them like the Camaro, so a pretty similar setup I'm guessing. Maybe that's what you're hearing?
http://www.g8board.com/forums/showthread.php?t=15543
UncleBenny is offline   Reply With Quote
Old 07-09-2009, 08:49 AM   #12
SicSix6
The Demon Photographer
SicSix6's Avatar
Drives: 2010 1SS IOM Camaro
squeal is the serpentine belt.
1SS IOM LS3, GM 4-pack guages, SLP SS Front Emblem, Roto-Fab CAI, Solo Performance Mach X Exhaust, Barton Industries Short Throw Shifter
SicSix6 is offline   Reply With Quote
Old 12-18-2010, 05:18 PM   #13
blackknight
Camaro Lover
Drives: 2014 GMC Sierra 5.3L
I noticed my L99 doing this today.....its going to the dealer this week anyways for the lifter tick noise on startup and for the spoiler paint chip dilema.
Hopefully its nothing serious and just the belt out of alignment.
No Camaro right now. But I'll be back in one in a few years.
blackknight is offline   Reply With Quote
Old 12-18-2010, 05:22 PM   #14
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
A day after this original post I never heard it again.
LS3 CAM AND HEADERS DYNO ADM PERFORMANCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 53 02-13-2016 06:15 PM
LS3 vs L99? SGOS252382 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 34 09-18-2010 03:55 PM
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 06:02 PM
Timing chain failures on LS3 vettes detroitboy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 15 04-12-2009 06:53 PM
Advice---Supercharged L99, S/C'd LS3 or LS9? CamaroZR1 Forced Induction - V8 25 09-25-2008 09:21 AM
