![]() Drives: 2012 2SS/RS Join Date: Apr 2013
My '12 SS is in the shop! (TSB for differential fluid)
My car has a little over 6000 miles on it and it sounds like something is rubbing in the rear end. The service advisor called and said there is a tsb to change the differential fluid for this issue. I hope it solves the problem.
![]() I just thought I would let everybody know in case anybody else is having a similar problem.
![]() ![]() ![]() Drives: 2010 CAMARO 2SS/RS WHITE Join Date: Jan 2011
Had mine changed. I STILL HEAR IT!
![]() Drives: 2013 ZL1 Black Join Date: Oct 2009
Known issue, corvette world too!
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '12SS/2SS/45TH-'06 2500HD/Silverado Join Date: Jul 2012
Ive got 4800 miles...when do you hear it, low speed, cruising or high speed?
#6 |
![]() Drives: 2017 Camaro ZL1 Join Date: Nov 2006
Isn't there also a TSB for a change to a bearing in the rear end? Thought I read that someplace on the forum
#7 |
Choke on that causality!
Drives: 2010 2SS/RS Join Date: Sep 2009
Yes this is a well known issue. I upgraded the rear-end fluid with Royal Purple, but still mine gets loud now and then. When that happens I find an empty parking lot and drive the car in tight circles (left and right) about ten times and it clears it up.
Edelbrock EForce - Stainless Works Headers - BMR Sways & Arms & Toe Links & Control Arm Bushings & End Links - Rotofab CAI - Assorted Interior, Exterior, Underhood Bling - Red Jewel Stripes & Full Body Clear - Lexani LX15 Wheels - JRE Fuel Rail Upgrade - Kenne Bell BAP - Heartthrob XPipe - Elite Catch Can - Pedders Cradle & Front Arm Bushings - Hotchkis Strut Brace - MSD Wires - Carbotech Brakes - DSS 1000HP Axles & Driveshaft - Mickey Thompson Tires - Halo Harness - AutoMeter A/F, Boost, Fuel Pressure Gauges - Whats Next?
#8 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: GM Vehicles Join Date: Jun 2010
Hi tom231,
I hope it solves the problem as well! Please let me know if further assistance is needed. Jessica Chevrolet Customer Care Quote:
#9 | |
I've heard it backing up also...just started recently. Is harm being done? Is it something that needs immediate attention?
#10 |
GM TSB states it's caused by a slip/stick of the posi-traction clutch plates. I have not read/heard of this causing any actual damage. They will change the rear fluid and seals, then drive in tight circles to distribute the oil and exercise the clutch plates to address the problem.
#11 | |
When I back out of the driveway. ![]() Thanks for the tip, will try driving in tight figure 8's.
