Oreo
Drives: Summit White LT/RS A6 Join Date: Dec 2010
Need some wiring help
How can I pass a wire from my center console into the door panels?
![]() Drives: 2012 Camaro 1LS Join Date: May 2012
What is this for? lighting the door panels?
Oreo
I have an RGB cable to light up the strips in my front speakers and the main controller is in my center console
Oreo
![]() ![]() Drives: 2018 ZL1 2015 1SS 1LE Join Date: May 2013
Can't you run it from the counsel, up to the dash, and then down to the doors thru the grommet with the factory wiring?
2018 ZL1 2015 1SS 1LE Stock...ish |
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '16 2SS Join Date: Apr 2011
As I recall, there are only a couple unused cavities in the door-harness connector that you can run wires through. You may need to drill holes.
#7 |
Oreo
I was thinking the same but the grommet is blocked off on both sides and I would probably mess something up of i tried to drill through it haha
#8 |
Oreo
Any other ideas?
#9 |
![]() ![]() Drives: 2011 Synergy Green Camaro LT Join Date: Jul 2011
Its not bad to drill out. There are a geoup of 3 or 4 empty slots together. I took a hot iron and ran it in the middle of them first to open it up then went in with my dremel. I was able to put a few 12ga wires through
| Tags |
| wiring help |
