08-14-2013, 01:00 PM | #1 |
Drives: 2012 CAMARO ZL1, 2012 CTS-V, Join Date: May 2012
ZL1 warm air out vents
Hi got 2012 ZL1 I have controls set to vent. As it's 63 out today get a lot of warm air out of the vents stop or moving Is this normal on zl1's
08-14-2013, 01:09 PM | #2 |
not sure if its normal....I noticed today I have the same issue....keeping the vents closed when not in use helps a little bit.
08-14-2013, 01:46 PM | #3 |
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
My car does the same thing so I think it's normal behavior.
In addition to closing vents, I have found pressing the recirculation button with the fan all the way off stops the hot air from blowing through the vents. Only annoyance is the recirculation button doesn't stay engaged across engine starts so you have to press it in everytime you start the car.
08-14-2013, 01:58 PM | #4 |
Drives: 2012 Blk ZL1 Join Date: Dec 2011
Yep it's normal just hit the recirculate button.
08-14-2013, 04:34 PM | #5 |
OK !!! So that mean we can't pull outside cool air in. on cool days??
08-14-2013, 04:55 PM | #6 |
Z-BEAST
Drives: 2013 JDP ZL-850 Track Spec ZL1, Join Date: Mar 2013
I have the same issue, and it is warm air.
08-14-2013, 04:58 PM | #7 |
Drives: 2013 Camaro ZL1 Join Date: Oct 2012
I'm considering insulating the intake box where the cabin filter is .I think its due to the fire wall getting so hot.
08-14-2013, 06:37 PM | #8 |
Drives: 1966 GTO Convertible/ZL1 Vert Join Date: Aug 2012
08-14-2013, 07:16 PM | #9 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
I posted about this over a year ago. It isn't cool, literally, because I always leave the vent on in my cars and the vent blows air that is hotter than ambient temp even when it is cool outside. I had to leave the vent off or run the AC. Apparently, it's normal for the 5th gen Camaro.
08-14-2013, 10:13 PM | #10 |
Drives: Getaway Special Join Date: Jan 2013
I got a little condensation dripping down from left rear of glove box area... what does that mean? AC was on full blast... not sure how condensation gets inside though.
Hiccup.
Sip:
08-14-2013, 10:36 PM | #11 |
BAD ZL1
Drives: 2013 VIN 48 Victory Red ZL1! Join Date: Jan 2012
Same thing here, thanks for the advice about pressing recirc with the fan off. Damn hot air on a cool day on vent sucks.
08-14-2013, 10:37 PM | #12 |
BAD ZL1
I think you are on to something, because it isn't hot air instantly, its like something has to heat up over time, like 10 or 15 min, then the air gets hot.
08-15-2013, 07:29 AM | #13 |
Drives: 2014 ZL1m6 red hot #569 Join Date: Dec 2009
its normal on all Camaros and f-bodies at least since the 3rd gens on up. ive owned about 5 Camaros since the '82 came out and every single one did it. the 3rd gens even had little vents on the console that seeped loads of hot air stock and even more after headers got put on.
08-15-2013, 08:37 AM | #14 |
Drives: 2012 Camaro ZL-1 SIM Join Date: Sep 2008
Even my 2010 SS did that. I also press the recirculation button to prevent the airflow.
