Old 08-15-2013, 02:18 PM   #1
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
How Much fluid for V8 M6 Trans and Rear Diff?
I am about to change my fluids and im unsure how much exactly i need to fill them up with? Where do you check the levels? And is there a specific torque spec i should be reaching for?
Any advice greatly appreciated!!
Nighthawk89 is offline   Reply With Quote
Old 08-15-2013, 02:29 PM   #2
Vroom_vroom
The gritos pollo!!!
Vroom_vroom's Avatar
Drives: Like a idiot
V6 or 8?
https://www.youtube.com/@FredJrsGarage
‘19 Silverado 3500 dmax
‘77 trans am
‘63 c2
Shopping for more Camaros
Vroom_vroom is offline   Reply With Quote
Old 08-15-2013, 03:07 PM   #3
Nighthawk89
Originally Posted by Vroom_vroom View Post
V6 or 8?
Forgot to put that in lol. V8!
Old 08-15-2013, 03:22 PM   #4
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
four quarts for tranny....I got five just to be safe
1 liter for the diff....I got 2 just to be safe
1 small bottle of diff additive
CHMSC is offline   Reply With Quote
Old 08-15-2013, 03:33 PM   #5
Stingr69
'69 Owned Since '79
Stingr69's Avatar
You will need 4 quarts of DEX 3 ATF fluid (I prefer Mobil1 Symthetic DEX3)for the 6 speed manual transmission on the LS3 engine cars. The shifts wil be smoother that way. Royal Purple has some good fluid as well but it will cost a LOT more.
You need a half bottle of GM limited slip additive plus 1 quart of proper weight gear oil for the rear end.
Don't try to read the bottle on the Mobil 1 Synthetic ATF - You will think you have the wrong stuff but it IS the right stuff. Look for the SYNTHETIC DEXRON 3 formula fluid designation. The ATF formulated for newer GM cars (DEX 5 for example) is NOT the right fluid regardless what the label says about the years it is compatible with.
You might like to have a funnel and 4 feet of clear rubber tubing to fill the transmission fluid from the top of the engine.
After you put the drain plug back in the rear axle, you add the limited slip additive to the rear first and then the gear oil after that.
-Mark.
Old 08-15-2013, 03:54 PM   #6
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
There's usually enough room in the top of the gear lube bottle to add the slip additive, which makes it easier to get into the rear end. Minus that, you could always put some of the gear lube in, add the additive to the remainder and continue filling.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 08-15-2013, 07:06 PM   #7
Nighthawk89
Do you have to have the additive with something like RP 75w-90?
How do i check to make sure i put the correct amount in both the trans and the rear??
Old 08-16-2013, 02:30 AM   #8
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Some gear lube comes with the additive and some doesn't. Be careful if you are trying to keep your warrant. RP and other brands will not be covered for warrant work FYI.
Fill it till it comes out. Make sure you are on a level surface and the car is level.
I used GM fluid and it made a huge difference in shifting....way smoother and no warranty concerns.
