Old 08-15-2013, 03:28 PM   #1
colingordon
Her Name is Mila
colingordon's Avatar
Drives: 2012 Camaro 1LT A6, 2014 Camaro 1LS
LFX Differential Fluid Change
Please can someone tell me the CORRECT differential fluid that goes into a 2012 LFX with the A6 AUTO transmission!?!?
Thank you!!
Colin Gordon
colingordon is offline   Reply With Quote
Old 08-15-2013, 04:14 PM   #2
sycraft
COTW 5/06/2013
sycraft's Avatar
Note: The following is for vehicles equipped with the 218mm Axle Limited Slip Differential option. The Limited Slip Additive container capacity is greater than the amount needed, only add the amount specified.
218mm Limited Slip Differential Lubricant Additive.
0.098 ml
3.3 oz.
195mm and 218mm Rear Axle Lubricant
0.9 L
1.0 Qt.
250mm Rear Axle Lubricant
2.3 L
2.43 Qt.
Rear Differential (218mm L/S Axle)
88900330
992694
Refer to Owner's Manual and Electronic Parts Catalog.
Rear Differential Lubricant (195/218mm Axle)
75W90 Axle Lubricant (Synthetic)
88900401
89021678
Rear Differential Lubricant (250mm axle)
Dexron LS Gear 75w90
88862624
88862625
Old 08-15-2013, 06:38 PM   #3
intensifi
Drives: '12 2LT Convertible
I have a '12 LFX auto.
I bought the fluid at the dealer.
I asked about the additive. The parts manager told me that it was only necessary for the manual transmission versions.
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
intensifi is offline   Reply With Quote
Old 08-15-2013, 07:06 PM   #4
Vroom_vroom
The gritos pollo!!!
Vroom_vroom's Avatar
Drives: Like a idiot
You don't have a limited slip on a v6 auto so no
https://www.youtube.com/@FredJrsGarage
‘19 Silverado 3500 dmax
‘77 trans am
‘63 c2
Shopping for more Camaros
Vroom_vroom is offline   Reply With Quote
Old 08-15-2013, 10:08 PM   #5
colingordon
Her Name is Mila
So if you have a A6 auto all you need is the AC Delco Fluid. NO slip addictive, correct?
Thank you
Colin Gordon
Old 08-15-2013, 10:20 PM   #6
intensifi
Thank you
Colin Gordon
That is correct.
This is one advantage of going to the dealer parts dept. They ask you for your vin #. This tells the computer what to provide when you ask for part X.
