Old 08-16-2013, 04:30 PM   #1
The Baron
The Baron's Avatar
Drives: 2013 zl1
blower dissemble and port
I have gotten several questions about blower dissembly and port work in the last couple months.
I will be doing a full disassemble and port on a blower starting sunday night..
I am going to take pics and short vids and and post them real time as I go...
this will be off a cts v but other than the lid removal (which I will go through anyway, the exact same process on your zl1 as they are IDENTICAL from the lid down.
I will show all tools needed and the puller required and how to make this yourself..
2011 cts-v coupe (pinky) wifes car.. ls9 cam c.a.i. 11.44
2007 corvette vert ..retired..
2013 zl1 stock blower stock ci 20" wheels 10.36 135...so far..
The Baron is offline   Reply With Quote
Old 08-16-2013, 04:40 PM   #2
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
Very cool!
BaylorCamaro is offline   Reply With Quote
Old 08-16-2013, 04:40 PM   #3
boondocksaint
Cartoon Maus
Drives: White ZL1, Chevroyota Prizolla
Subscribed, just because I like to see the work.
boondocksaint is offline   Reply With Quote
Old 08-16-2013, 04:52 PM   #4
Whos_Drivin
Drives: '12 Camaro ZL1, '16 Silverado Z71
Lookin forward to it!
2012 ZL1: M6, Rotofab CAI, ATI balancer w/8.66 overdrive, PFADT long tube headers w/cats
2016 Silverado LTZ-Z71 Midnight Edition: 6.2L, 8 speed auto, Borla exhaust
Whos_Drivin is offline   Reply With Quote
Old 08-16-2013, 05:00 PM   #5
4fbodys
4fbodys's Avatar
Drives: 3 3rd gens 1 4th gen
Dump question but since you are doing this, totally looking forward to the vids and pics badass, anyway does anyone know if the blower snout can be pulled without pulling the whole supercharger or do you have to take off the whole thing as one thanks
2012 ZL1 & my wife
4fbodys is offline   Reply With Quote
Old 08-16-2013, 05:00 PM   #6
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
Thank you in advance. I don't ever plan on doing it myself but would like to see what is happening.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 08-16-2013, 05:31 PM   #7
charlietuna
charlietuna's Avatar
Drives: 2013 ZL1
Thank you x100 for this
Laus Deo
charlietuna is offline   Reply With Quote
Old 08-16-2013, 05:57 PM   #8
Al C.
Al C.'s Avatar
Drives: ZL1 #529 "El-Jefe"
Subscribed..
Al C. is offline   Reply With Quote
Old 08-16-2013, 06:03 PM   #9
3monkeys
3monkeys's Avatar
Ready!
3monkeys is offline   Reply With Quote
Old 08-16-2013, 06:32 PM   #10
Silverguardrail
Silverguardrail's Avatar
Drives: 2012 ZL1 #1448
Cool ! Thanks in advance !
2012 ZL1 SIM, MN6, B92, RTQ
ZL1 - the true definition of joy ride
Silverguardrail is offline   Reply With Quote
Old 08-16-2013, 06:34 PM   #11
white ZL1
Drives: none
Sub'd!
white ZL1 is offline   Reply With Quote
Old 08-16-2013, 07:33 PM   #12
AMMUSCLE
AMMUSCLE's Avatar
Drives: 2013 ZL1 VERT M6
Thanks ahead of time.
Can you also do a written play by play for others to follow including specs, disassembly instructions, assembly instructions including torq specs.
Thanks
AMMUSCLE is offline   Reply With Quote
Old 08-16-2013, 10:54 PM   #13
The Baron
The Baron's Avatar
Drives: 2013 zl1
Ill do my best.. and no.. you have to remove the lid then loosen all 10 bolts that hold it down to remove snout. The front of the blower must be elevated to remove and install.
The pics and vids will walk you through that part as most guys will never do more than that ( replacing upper pulley)
The lid on the zl1 is actually a very time consuming part of the process because the back 6 bolts are a biiiiiiaaaaaaatch.
Old 08-16-2013, 11:06 PM   #14
Smittty
Smittty's Avatar
Drives: 2013 ZL1 Camaro 2000 SLP Camaro
Smittty is offline   Reply With Quote
