Old 08-17-2013, 04:02 PM   #1
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Talking Swappin' Gears
Warning: Installation of rear end gears should only be performed by professionals. As owners of the 5th generation Camaro continue their pursuit of more performance, many are swapping to a more aggressive set of rear end gears. While not an inexpensive modification, the bang for your buck with a rear end gear swap is hard to beat and the improvement in performance is dramatic. Making this sort of modification can be intimidating because many people don’t understand differentials and gearing. In this post I will try to provide some basic information to at least try and help get you pointed in the right direction.
How It Works
The rear differential is the device that transmits torque and rotation from the driveshaft to the rear axles which then drives the rear wheels. The rear end gears contain a ring and pinion gear that can be swapped to different ratios. The stock Camaro comes with either a 3.27 (all V6 models and the automatic SS) or a 3.45 (manual SS) rear end gear ratio. This means that for every 3.27 or 3.45 rotations of the drive shaft your rear wheels will turn once. A lower gear ratio means increased torque and increased acceleration without the engine having to create any additional power.
This all sounds great but the are some potential draw backs. A lower gear ratio means that your engine has to turn faster at cruising speeds which means fuel mileage can suffer. In the case of the 5th generation Camaro, the new six speed transmissions help mitigate the impact of this. Camaro owners that do a lot of highway miles have been reporting a loss of about 1-2 MPG, while those who drive mostly in town are reporting no change and even an increase in some cases due to the engine not having to work as hard to get up to speed.
The other potential draw back is that a lower gear ratio will shave away top end speed. This is not important to the average Joe since the Camaro is capable of speeds well beyond the speed limit right off the showroom floor, but for competitive drag racers it can be. It is possible that while the lower ratio will cause your car to accelerate faster it can also cause you to have to shift gears one more time before you cross the finish line, potentially sacrificing the gains made. Careful calculations should be made when selecting the correct ratio for these sorts of applications.
The Numbers
Camaro V6 Models
Currently, there is only one gear ratios made specifically for the 5th generation V6 Camaro. For the V6 Camaros Richmond manufacturers a 3.55 gear ratio. With the stock 3.27s the automatic (A6) equipped V6 runs 1750 RPM at 70 MPH. Swapping to the 3.55s provides an equivalent torque gain of approximately 10% or 27.3 ld.-ft. of torque and will raise 70 MPH cruising RPM to 1949.
The V6 Camaros equipped with the manual transmission (M6) come with 3.27s and run 2000 RPM at 70 MPH. Swapping to the 3.55s provides an equivalent torque gain of approximately 9% or 27.3 ld.-ft. of torque and will raise 70 MPH cruising RPM to 2167.
The rear end in the M6 equipped V6 Camaro is similar enough to the SS that their gears will also work. Apex Motorsports recently had a customer install Richmond 3.73s in his car. The result was an equivalent torque gain of approximately 15% or 40.95 lb.-ft. of torque and will raise 70 MPH cruising RPM to 2277.
Camaro SS Models
The Camaro SS models currently have three aftermarket gear ratios available for them; 3.73, 3.91, 4.11, and 4.33. When equipped the the automatic transmission (A6) the SS comes with a 3.27 rear end and cruises at 1795 RPM at 70 MPH. By upgrading the factory 3.27s in the stock A6 equipped Camaro SS to the 3.73s you will realize an equivalent torque gain of approximately 15% or 61.5 lb.-ft. of torque and cruise at 2050 RPM at 70 MPH. By upgrading the factory 3.27s in the stock A6 equipped Camaro SS to the 3.91s you will realize an equivalent torque gain of approximately 20% or 82 lb.-ft. of torque and cruise at 2150 RPM at 70 MPH. By upgrading the A6 to the 4.11s you will realize an equivalent torque gain of approximately 27% or 110.7 lb.-ft. of torque and cruise at 2250 RPM at 70 MPH. By upgrading the A6 to the 4.33s you will realize an equivalent torque gain of approximately 33% or 135.3 lb.-ft. of torque and cruise at 2377 RPM at 70 MPH. The A6 transmission is geared more aggressively than the M6 SS so we have found that 3.73 is a great gear for most A6 equipped SS applications.
When equipped with the manual transmission (M6) the SS comes with a 3.45 rear end and cruises at 1612 RPM at 70 MPH. By upgrading the factory 3.45s in the stock M6 equipped Camaro SS to the 3.73s you will realize an equivalent torque gain of approximately 10% or 42 lb.-ft. of torque and cruise at 1750 RPM at 70 MPH. By upgrading the stock M6 equipped Camaro SS to 3.91s you will realize an equivalent torque gain of approximately 13% or 54.6 lb.-ft. of torque and cruise at 1800 RPM at 70 MPH. By upgrading the stock M6 equipped Camaro SS to 4.11s you will realize an equivalent torque gain of approximately 20% or 84 lb.-ft. of torque and cruise at 1915 RPM at 70 MPH. By upgrading the stock M6 equipped Camaro SS to 4.33s you will realize an equivalent torque gain of approximately 25% or 105 lb.-ft. of torque and cruise at 2025 RPM at 70 MPH. We have found that the 3.91s and 4.11s are great gear options for most M6 equipped SS street applications. Once the 550-600 rear wheel horsepower range is reached we recommend dialing back to 3.73 unless the vehicle has a very solid suspension package and a very competent driver.
Make It Happen
Hopefully, the information in this post has helped you better understand gear swaps. If you think a gear swap may be right for your project be sure to consult a professional, like the experts at Apex Motorsports, during your decision making process.
Old 08-17-2013, 05:30 PM   #2
MikeMoach
MikeMoach's Avatar
Drives: 2010 RJT 2SS/RS
Great info like always Chase
MikeMoach is offline   Reply With Quote
Old 08-17-2013, 09:07 PM   #3
Ron66Vette&10SS
Plays with Hot Wheels
Ron66Vette&10SS's Avatar
Drives: '17 Jet Black ZL1
I'm no math wiz, but I'm guessing that in an M6 car going to 3.91's over the stock 3.45's would be around 15% gain for approximately 63 more lbs.tq......right?
Previous Cars: '78 Z28, '92 Z28, '95 Z28, '85 Corvette, '01 SS, '96 Z28, '04 Z06 Corvette, '10 SS, '13 SS Hot Wheels
Current Cars: '17 ZL1(daily driver), '04 Trailblazer (rain & snow), '66 Corvette (restoring)
Ron66Vette&10SS is offline   Reply With Quote
Old 08-18-2013, 10:45 AM   #4
Apex Motorsports
Thanks!
It is the weekend and I can't force myself to do the math right now but that is about right.
Old 08-18-2013, 05:27 PM   #5
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
4.33 would rock on a track if u can hook it. Fat car likes gears.
-John S.
Old 08-18-2013, 08:42 PM   #6
13BlackCamaroSS
13BlackCamaroSS's Avatar
Drives: 2016 Camaro 2SS
Good info as I am thinking of switching gears. Thanks
Race what you brung, Hope you brung enough
2016 2SS, NPP, Adrenaline Red Leather and Pads, 6sp, Sunroof, Black Bowties, Upgraded Wheels, 15% Tint, Kooks Headers, MBRP Exhaust, 1LE Wheels, Badging, Ported Throttle Body, Procharged, Snow Performance Stage 2 Meth Kit
Coming Soon: Custom Cam, E85, Ported Heads
13BlackCamaroSS is offline   Reply With Quote
Old 08-19-2013, 07:13 PM   #7
Apex Motorsports
Great timing then! Feel free to hit me up if you have any questions.
Old 08-19-2013, 08:40 PM   #8
Stingraye
Stingraye's Avatar
Drives: 2011 2SS / RS M6 LS3 IBM
Love my 3.91's, they're a great set in an M6 SS
Stingraye is offline   Reply With Quote
Old 08-19-2013, 10:27 PM   #9
Jason@JacFab
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
Nice write up! Should add info about the 2.92 ratio in the 2ls automatic, and perhaps show the mathematical benefit of swapping to even the 3.27 auto v6 gears or the 3.55.
Jason@JacFab is offline   Reply With Quote
Old 08-19-2013, 10:48 PM   #10
hunterv6
Always bet on Black
hunterv6's Avatar
Drives: 2011 turbo LS, 2012 f 150,
Great info
sent form my mini computer note 2
<font color=#0066cc>http://www.camaro5.com/forums/showthread.php?t=283263</font>
hunterv6 is offline   Reply With Quote
Old 08-20-2013, 08:09 AM   #11
msp2887
msp2887's Avatar
Drives: 2011 2SS/RS Black
What do you think of the 3.73 vs. the 3.91 for the A6?
msp2887 is offline   Reply With Quote
Old 08-20-2013, 10:06 AM   #12
13blackLS
13blackLS's Avatar
Drives: 2013 camaro ls; 2005 rx8
Where can i find more info on this? As i have a 2ls...any help or info on where to rwad up on this is greatly appreciated...thanks!
13blackLS is offline   Reply With Quote
Old 08-20-2013, 10:12 AM   #13
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr
I know yours is a SS and mine is the RS, but i will have a good answer for you tomorrow. I stepped up to 3.73 from 3.27 a few months ago and tomorrow we needed to do a gear swap and only thing on hand is a set of 3.91's. I will post back if i see much of a difference in performance, regular driving, and mpg.
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS.
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47**
Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver
Daily Driver 2021 BMW M340i Xdrive
IneedAZ is offline   Reply With Quote
Old 08-20-2013, 10:21 AM   #14
msp2887
msp2887's Avatar
Needed to do a gear swap? Were there issues w/ the 3.73s?
3.73, 3.91, 4.11, gear ratio, gears swap
