Old 08-23-2013, 05:58 AM   #1
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
Install and testing of the Vmax ICEOlater and ported Throttle body
We started with the LLT go kit consisting of the Vmax ported LLT throttle body and the Black ICEOlator. We didn't use the top spacer for our test. We just bolted on the ICEOlator and throttle body. The kit comes with instructions, but Ill post them in this thread.
JC615's completely stock LLT Camaro on the DynoJet 248
Tampa Tuning is offline   Reply With Quote
Old 08-23-2013, 06:07 AM   #2
Tampa Tuning
ICEOlator in place and it stays there pretty natural while your adding silicon to the manifold.
Now was the best time to add the ported vmax throttle body
having two sets of hand on the manifold made it easier to set on top of the block and lining up the bolts
Start to reconnect the hoses
Old 08-23-2013, 06:10 AM   #3
Tampa Tuning
DIY Install
And she put back together in an hour
Old 08-23-2013, 06:13 AM   #4
Tampa Tuning
LLT DIY install of ICEOlator and throttle body
you can see in the 3300 -5500 RPMS zone where timing didn't drop off in run 4 like it did in run 2 causing less power.
Old 08-23-2013, 06:16 AM   #5
Tampa Tuning
DIY ICELator installation
better picture of the bracket not reused because the manifold sat up a little higher. total install was under an hour
Old 08-23-2013, 10:42 AM   #6
flyer08
Drives: 2010 2SS/RS
Drove car after and you can tell a large difference around the 3200-4500 rpm range where we saw the biggest improvement
flyer08 is offline   Reply With Quote
Old 08-23-2013, 11:33 AM   #7
KMPrenger
KMPrenger's Avatar
Very nice to see another good test of the TB and spacer on the LLT. This is a very good bang for your buck product!
Old 09-02-2013, 09:02 AM   #8
flyer08
Drives: 2010 2SS/RS
I will have to verify and have her run some numbers but she said she thought she was getting better gas mileage as well?
Old 09-02-2013, 09:13 AM   #9
spyderbuddy
Question, what would happen if we milled 3/8 off the bottom of the IM and the ported the intake to the i cel a tor, and the used the IM plenum spacer?
Old 09-02-2013, 01:05 PM   #10
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
Why the father away from the block the better. Don't want to heat sink the IM! I Just ported the ports to match the ICO lator
Old 09-02-2013, 01:05 PM   #11
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
Nice write up, power tools and gloves?
Old 09-02-2013, 05:26 PM   #12
Tampa Tuning
I guess you can do that mill 3/8" off the intake, but A) that's a lot of effort and takes away the bang for the buck, B) with the ICEOlator you have a little longer runner combined with the reduced heat soak.
If time is on your side, Match porting will help, but I just wanted to test the way most guy do their install.
Kind of like going to the doctor...... if you call electric ratchet drive socket a power tool. lol
Old 09-02-2013, 05:31 PM   #13
Tampa Tuning
Id say its from applying less throttle to move the car. With less heat soak, it can use more timing for better efficiency.
Old 12-28-2013, 10:20 PM   #14
flyer08
Drives: 2010 2SS/RS
Jen is going to run a test to see if mpg difference between regular and 93 she'll vpower. Will post results in couple weeks after run a few tanks of both
