Old 08-23-2013, 04:56 PM   #1
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
Twin disk clutch recommendations
Im converting an auto car to manual, and looking into picking up a twin disk clutch, and im not sure what to get.
they seem to run between 1-2 grand on average.
This would be mostly street use, with occasional drag use.
id like smooth engagement, with not too heavy of a pedal that will hold about 550 crank hp.
Any recommendations?
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 08-23-2013, 07:28 PM   #2
Steve@SNL/Monster Clutch
Drives: 2014 SS
At your current level our single would get you taken care, what are your future power goals?
Steve@SNL/Monster Clutch is offline   Reply With Quote
Old 08-23-2013, 08:33 PM   #3
nighttowl
nighttowl's Avatar
Im going to stroke the motor out to 416 Cu.
Old 08-24-2013, 01:55 PM   #4
Drives: 2014 SS
If you plan on staying NA, then our Level 1 twin would be what I would recommend. Feel free to call me if you have any questions, Chris 817-750-2000
Old 08-24-2013, 06:25 PM   #5
gnturboray
gnturboray's Avatar
Drives: SIM 2010 2SS/RS LS3 LPE750
Mcloed RXT rated to 1000hp and as soft as stock.
gnturboray is offline   Reply With Quote
Old 08-24-2013, 10:22 PM   #6
Matt @ FSP
Matt @ FSP's Avatar
Drives: 2011 Camaro SS
Mantic 9000 Series Twin Clutch Kit
The Mantic 9000 series is the smoothest engaging, softest feel to a clutch that I have ever had in a LSx car that can handle over 1000rwhp !!!
The clutch feels as light as the LS3/LS7 clutches, weighs in at 37lbs with the steel billet flywheel (Good for big cams instead of the aluminum fw), awesome engagement, and great in traffic. We use them all the time, got one going into a 850rwhp Vette now and another in a 800rwhp Camaro. The 9000 series twin kits also include the proper Slave Cylinder, TO Bearing, and all associated hardware (Floaters, discs, pressure plate).
Mantic ER2 Single Clutch Kit
However, for your 550rwhp you can also use their single which is about half the cost. The single ER2 design feels like stock clutch with smooth engagement, weighing in at 49lbs with steel billet flywheel. Cover Assemblies with the ER2 Groove Design feature have a unique groove pattern CNC machined on the friction face of the Pressure Plate. The groove has been specifically designed to increase the Mean Effective Radius of the pressure plate and assist in heat removal.
EVERY SINGLE MANTIC CLUTCH IS DYNO TESTED BEFORE IT LEAVES THEIR FACILITY. Not many clutch manufacturers can claim that.
Matt @ FSP is offline   Reply With Quote
Old 08-26-2013, 02:34 PM   #7
H-E
Drives: 2010 zr1 Camaro 2011 vert
Do a search on this site,after all you have a camaro any other reference would be worthless then give us a call and we can get you the right clutch the first time and save you the money and headache.....
H-E is offline   Reply With Quote
Old 08-26-2013, 06:27 PM   #8
MikeOD
Drives: 2010 M6 2SS
I don't see a lot of people talk about Exedy...they're expensive clutches. Mine is smooth as glass, and no matter what I do, it does not slip. Pedal feel is just about stock.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension
MikeOD is offline   Reply With Quote
Old 08-31-2013, 10:01 PM   #9
H-E
Thanks fpr the orders guys!.....hand built clutches specific to your new camaro!
Old 09-07-2013, 02:50 AM   #10
BDON_DBB
BDON_DBB's Avatar
Drives: 2010 Camaro SS D1SC
Mcleod rxt. Got 700rwhp and no probs there.
BDON_DBB is offline   Reply With Quote
