Old 08-29-2013, 01:20 PM   #1
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
Built my own 3" exhaust!!
So I decided to build my own 3" exhaust, I kept it dumped at the rear. I will try an get a clip up later but its sounds awesome and fit perfect! I am set to hit the dyno again next month for a tune update, pretty sure my car is far from optimum right now.
Since my tune I now have full 3" right off the headers, a much bigger filter with a straighter shot to the TB, and I switched to LS7 plugs. Hoping I pick up another 15hp or so and a little more trap speed.
How far you guys think my tune is off right now? As far as the butt dyno I cant tell, its way to hot out right now and my car always dogs bad in this heat! Last time when it was tuned I had the full stock exhaust on and a tiny air filter that he said was choking me!
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 08-29-2013, 01:38 PM   #2
Switchin2Chevy
Drives: Currently 2015 Mustang GT manual.
Switchin2Chevy is offline   Reply With Quote
Old 08-29-2013, 01:47 PM   #3
SSCam77
Drives: 427
Nice job so far, I love the DIY stuff...
check out @LSX_CANADA on Instagram.
SSCam77 is offline   Reply With Quote
Old 08-29-2013, 01:52 PM   #4
great job, I'll be watching for the video
Old 08-29-2013, 01:56 PM   #5
Bad70supreme
Thanks, I also located the H 18" from the collectors. The stock H was much further down the tube, so hopping this might add some torque as well. I was able to even add ground clearance over the stock setup in the middle of the car!
Old 08-29-2013, 02:13 PM   #6
SNSSTR
All About That Speed
SNSSTR's Avatar
Drives: 2010 Camaro 2SS/RS
So you're going to do mine when I come over right?
Looks great man! Good work!
2010 SS M6 | 416 CI | H/C/I | GPI TUNED | SNSSTR
SNSSTR is offline   Reply With Quote
Old 08-29-2013, 02:15 PM   #7
Scooter18155
Scooter18155's Avatar
Drives: 2010 ss/rs 6 speed manual
May I ask why no x pipe?
2010 camaro ss/rs, standard 6 speed, ls3 motor, bmr subframe connectors, jba 3” competition Exhaust, stainless works 1 7/8" headers, adm cold air intake, hurst short throw shifter, bo white ported tb, mishimoto aluminum radiator, mishimoto oil cooler.
Scooter18155 is offline   Reply With Quote
Old 08-29-2013, 02:19 PM   #8
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Not bashing, but I did read a thread where dyno and flow tests were done with an x pipe and an h pipe in a bunch of different locations, and the tester found the stock location was optimum, any other location resulted in a loss of power or no change at all.
Might have been Ted janetty but dont quote me on that. Definitely on this forum though
Old 08-29-2013, 02:25 PM   #9
Bad70supreme
I would find a loss of power hard to believe, that would suck thats for sure! Everything I read said to put the H close to the headers as possible. I am about 5" closer then the stock location. I stayed with a H because I like the old school sound over an X.
Old 08-29-2013, 02:38 PM   #10
62nalide
62nalide's Avatar
Drives: 2013 SS
X-pipe would of been better.
Either way you got skills nice bends man!
62nalide is offline   Reply With Quote
Old 08-29-2013, 02:44 PM   #11
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Nice, did you mig or tig that?
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 08-29-2013, 02:45 PM   #12
Bad70supreme
Who knows maybe next year I will try an X, thanks though its only my 3rd exhaust build! I did my 70 cutlass and a friends G body in 3" also. I think this is my best one so far!
Old 08-29-2013, 02:54 PM   #13
Bad70supreme
I use a weld pack 100, flux corded. I could have done a better welding job, took me bit to find the setting that worked for me and I was being impatient LOL
Old 08-29-2013, 03:27 PM   #14
SNSSTR
SNSSTR's Avatar
It was Ted Janetty. I can't find the post, but I do remember him being the one to post that.
