Old 08-29-2013, 02:35 PM   #1
CrisisMusick
Drives: 2014 AGM 1LE/2SS/RS
Need help: Weird Rattling Sound in SS
I just traded in my M6 LS for a 1LE/SS, and I've noticed that in low RPMs I hear a rattling noise underneath my shifter or pedal, but the rattling stops when I press down on the clutch. I can't tell if it's still rattling on higher RPMs because my quad exhaust noise covers any other sound, but I was wondering if this is a normal occurrence or if I should go into Chevy to see what's going on?
Thanks for the help!
CrisisMusick is offline   Reply With Quote
Old 08-29-2013, 03:37 PM   #2
Billetmaster
Drives: 2011 SGM 2SS/RS
I had that. After a couple of trips, they told me that it was a metal tag on top of the transmission that had come loose.
Billetmaster is offline   Reply With Quote
Old 08-29-2013, 03:59 PM   #3
gafool
gafool's Avatar
Drives: 2010 1SS CGM
could be a rattlesnake? i hear its fords newest engine platform? they will make them out of the focus and fiestas! lol
gafool is offline   Reply With Quote
Old 08-29-2013, 06:28 PM   #4
CrisisMusick
Did they fix it? And was it covered by warranty?
Old 08-29-2013, 06:46 PM   #5
strych9
I'll be back...
strych9's Avatar
Drives: Subaru, HD Road Glide Special
It might be normal manual "gear rollover". If the innards are turning in neutral, they can bang around a bit with the cylinder firing pulses. Sounds a little bit like marbles in the transmission.
Bye bye, Bumblebee!
Old 08-29-2013, 07:08 PM   #6
jcamo
jcamo's Avatar
Drives: 2ss/rs/2013 camaro 1LE
check this out.. http://www.camaro5.com/forums/showthread.php?t=280996
jcamo is offline   Reply With Quote
Old 08-29-2013, 07:57 PM   #7
Cam 427
Cam 427's Avatar
Drives: 2010 2SS
Seems like many Camaros are afflicted with this, mine included. I talked to Tremec about this and they said it was gear clash and due the pulses in the engine it would possibly sound like a rattle. I had a 99 SS with a T56 and it didn't do this. There must be clearance differences between the T56 and TR6060.
Cam 427 is offline   Reply With Quote
Old 08-29-2013, 11:09 PM   #8
Bob1475
Bob1475's Avatar
Drives: 2013 Victory red 1SS 6spd
I had the same rattle and it drove me nuckin futs. I finally took off the passenger side trim piece on the console and found a connector hitting the underside of the console that worked it's way loose. Stuck it back and used a little tape. Problem solved.
Bob1475 is offline   Reply With Quote
