Drives: 2010 2SS/RS Join Date: Jan 2013
My TSP 2" feedback
Very nice headers to begin with they went right in.
2 issues though... 1.do not use the gaskets provided with them as part of them block 2 spark plug holes It was a pain in the ass changing them plugs that were blocked by the gasket. I had to cut it a lil with a Dremel to get the plugs out. 2.i noticed my passenger side had a rough sound like something was loose every time I would start it. Lifted again to see this one of the primaries is hitting :( Anyone else have this issue ? Its no biggy for me I'm still happy with the performance just thought id give a heads up
#2 | |
Drives: White 2010 RS/SS Join Date: Dec 2009
You think he will get me a new one even though I ran them one day? All I need is the passenger side
Now that u say that my car did feel like it wasn't running right. |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
You'll never know of you don't call.
I called but too late now. Ill try tomorrow
I just don't want my car down since its the daily hopefully they can jut send me this one if not ill just grind the subframe I really don't wanna hit the header. |
#6 |
![]() Drives: 2011 SS/RS LS3 Join Date: Oct 2010
I had a driver side primary hitting the upper aluminum portion of the engine mount (fixed by grinding mount) and the same spot on the passenger side sub frame which I notched and welded in a small cut up piece of 1"x1" angle iron.
A dent in the primary would have been easier but I didn't want to do that. |
#7 |
instigator
Drives: 2020 6.2 Trail Boss, 2022 XC90 Join Date: Jan 2010
I'd be getting another header or dinging it before I cut on my car. That's bs.
-John S.
#8 |
Svt lol
Drives: 2011 ss inferno orange blown Join Date: Jan 2012
I never had issues with my headers even used the gm gaskets they sent with the kit no issues. And the gaskets they send I was told are the gm set so not fitting correctly makes me think you might have done something wrong. But I'm not there so I don't know.
#9 |
![]() Drives: 2013 SS/RS Join Date: Jul 2013
I know the directions that came with my pfadt headers spacificaly said "be sure to watch the gasket for clearance around the spark plug holes" so I'm guessing its a common mistake? I reused the stock gaskets and didn't have any issues. Bending a "little" metal isn't a big deal. My LG super pros on the Vette needed a little love to fit. But I wouldn't cut anything! Give them a call as others said. If for some reason they are not willing to work with you, I'd remove them and get a different set. I'm guessing they will though. There are lots of happy customers running them.
#10 |
Naw man I for sure aint doing anything wrong on my end as iam a mechanic lol anyways
These aren't gm gaskets that's for sure lol there's a big difference but since I removed the header I went ahead and reused my oem gasket! You can see the difference here as I laid the oem gasket on top of the TSP ![]() I went ahead and removed the header and made a notch in my cradle instead of hitting the header.
#11 |
instigator
oem gaskets for sure...always best bet.
I wouldn't have touched the cradle just 'cause that crap is supposed to fit dang it.
-John S.
#12 |
Svt lol
Then they must have sent you the wrong ones that sucks.
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 aqua blue SS/RS M6 Join Date: Feb 2010
I have XS powers... I had the same problem, it was just touching it so I used a socket and put a very small dent it the tube there. No big deal, you cant even see it!
10.91 at 122 H/C stock block N/A
#14 |
![]() Drives: '12 2SS/RS, '13 Vette, '13 Wrangler Join Date: May 2012
My TSP 2" didn't seem to be hitting anything that I remember when I put them in. I will look next time I raise the vehicle.
2012 Camaro Ashen Grey Metallic 2SS/RS "Timberwolf". Custom exhaust, RX oil catch can and oil breather, CAI inc intake, SLP 160* thermostat, TSP 2" LT headers w/ off road pipes, custom cam, tuned. 467rwhp 450rwtq.
2013 Corvette Torch Red LS3. 378rwhp/375rwtq SAE corrected, tuned. ROCK CHALK JAYHAWK GO KU! |
