Old 09-01-2013, 12:22 PM   #1
lUvMymaRo98
StingrayFleetBusinessMgr
lUvMymaRo98's Avatar
Drives: 2013 Camaro Convertible 2LTRS
Hit a curb, need some encouraging words!
Hi guys, moment of shame here. I hit a curb head on at about 20-25 mph
Drivers front, tire popped, put donut on and noticed steering wheel cocked to the right when driving straight. Now the new tire is on and the wheel is cocked out at the top. Shop cannot align -we also replaced a bent lower control arm. I am scared to death that my engine cradle moved? Any ideas on the chances of that or how big of a mess I have here. Is this fixable? and can I get a new subframe if I have bent mine? argh! need some support!
6-16-09 -2010 Camaro LT coupe-IOM
3-11-11- 2011 Camaro LT Convertible-IOM
8-09-12- 2013 Camaro 2LT/RS VERT -IOM
lUvMymaRo98 is offline   Reply With Quote
Old 09-01-2013, 12:48 PM   #2
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
If the engine cradle moved to put +camber on the driver side, that will normally put more negative camber on the passenger side. This is one thing you can probably check for yourself, and you can get pretty good numbers with a digital angle finder is you have a flat area to set up on.
Did the shop tell you just why they could not align it?
Norm
Norm Peterson is offline   Reply With Quote
Old 09-01-2013, 12:51 PM   #3
qcman
qcman's Avatar
Drives: 2013 Camaro 2SS RDP Tuned L99
Sorry man I can only provide moral support but you have it.... I know that sick feeling though mine was less than 5 mph & seems okay. Anyways I'm sure some smarter guys here can help. At the very least you might want to have your dealer have a peek at it & see.
Cam
qcman is offline   Reply With Quote
Old 09-01-2013, 01:03 PM   #4
lUvMymaRo98
I took it into work (I work at my dealership) and after the new lower control arm was put on w a new tire the top of the drivers wheel was leaning out away from the car. They said we need to wait until Tuesday when another mechanic was there. I think we were only running a skeleton crew since it is a holiday weekend. They also mentioned she may be going to the body shop. I cannot believe this. Hoping for just a few more bent parts and no subframe involvement.
Old 09-01-2013, 01:04 PM   #5
lUvMymaRo98
Good point about the passenger side Norm, I didn't think to look or ask, I was just staring at that drivers side thinking #$%^^&*&*
Old 09-01-2013, 01:35 PM   #6
Mmar88
Drives: 2013 BRM 2SS/RS/1LE/NPP/NAV
Hey I'm sorry to hear what happened ! Best of luck with it!!!
Mmar88 is offline   Reply With Quote
Old 09-01-2013, 02:40 PM   #7
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
Don't hit curbs, they are baddddd.
A good alignment shop or body shop should be able to help you find your problem. Although, even they can over look thins. I found my issue myself by putting the car on a rack and eyeing everything from side to side and comparing them. Take your time and do not rush while doing this.
CHMSC is offline   Reply With Quote
Old 09-01-2013, 03:22 PM   #8
FAT-SS
unBALAnced-10
FAT-SS's Avatar
Drives: 2010 Camaro SS
I hit a curb last December going about 20 - 25 mph also. The windshield fogged up and by the time I figured out how to turn on the defroster, BOOM. Front tire was flat, the drivers front wheel was dented badly and the rear drivers side wheel had a bad gouge but not dented. At least you only banged up the stock wheels. Mine were TSW Vairano's and I only had them for a year and a half before I had to replace them. Since TSW no longer make the Vairano's, I got the TSW Rockinghams on now. I had the same alignment problem also after I hit the curb with the Camaro pulling to the right. I took it to Firestone to get it aligned (lifetime alignment) and they wanted to drill a larger hole in the front drivers side strut so that they could align it and charge me $200 for labor (no new parts). I told them no thanks and I purchased a new strut (since the strut was bent from hitting the curb) and put it on myself then brought it back to Firestone for them to align again. Works fine since then AND I got new Wheels now. I only have pics of the rims after the tires were removed and a pic of the Camaro with the TSW Rockinghams. Now you have a good excuse to get new wheels too.
FAT-SS is offline   Reply With Quote
Old 09-01-2013, 03:26 PM   #9
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
Yeup happened to me the traction control light was on bent lower arm, scuffed up the rim, GM has a exchange progam for that. The dealer did a five wheel alignment, it is better then ever. 1100 gm dollars later. Expensive hobby
Old 09-01-2013, 04:20 PM   #10
EastWood-SS
Born To Run
EastWood-SS's Avatar
Drives: 2013 BRM SS/RS LS3
It's OK... judging from your pics, atleast you remain physically attractive at the end of the day. Look in the mirror -- That should make you feel better. B)
Just Lettin' the Night Roll...
2013 Blue Ray Metallic 1SS/RS
Dual Mode Exhaust + Fuse Pull / CAI inc. CAI/ 1LE Strut Tower Brace/ ACS T4 Splitter/ SunRoof/ BA Audio/ Performance Shifter/ White Rally Stripes
EastWood-SS is offline   Reply With Quote
Old 09-01-2013, 04:22 PM   #11
KJS
KJS's Avatar
Drives: '10 RJT,'95&'14 Vette
Question
Five wheel alignment? Never heard of this. What does it entail?
"As ye sow, so shall ye reap" - Me
Mine at sunset
KJS is offline   Reply With Quote
Old 09-01-2013, 04:26 PM   #12
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
I'm sure they will get the car straightened out for you, be thankful you work for a dealership.
Old 09-01-2013, 05:16 PM   #13
Fiftydriver
Fiftydriver's Avatar
Drives: 2010 Camaro 2SSRS RJT L99
Not much to add for encouraging words other then I am sure the frame is not bent so its likely its repairable.
What I would say is Don't hit curbs, let alone at 25 mph!!!
Fiftydriver
2010 SSRS, RJTC, L99, Maggie 2300 SC, 3.4" pulley, Roto-Fab CAI, Dynatech Supermaxx LT headers, Dynatech High Flow cats, Corsa Cat back exhaust, Dual Elite Engineering catch can, MSD wires and Jannetty custom tune, JRE custom diff w/ posi mod, 3.91 LPE gears, Pfaht trailing arms, Pfaht trailing arm and Diff bushings, drop springs and sport sway bars front and back, Fesler dual guage pillar pod w/ AM Cobalt Boost and A/F guages.
More to come!!
Fiftydriver is offline   Reply With Quote
Old 09-01-2013, 05:41 PM   #14
rrpilot
Drives: Chevy Trailblazer, Ford Flex
I'm sure it was 5 angle alignment not 5 tire.
rrpilot is offline   Reply With Quote
