Old 09-03-2013, 01:44 PM   #1
Donovanl1685
Drives: 2012 Camaro ZL1
No Cats question
I was thinking about removing my cats, I know it will throw a code. My question is, will it make much louder,Will there be lots of drone? Is there a company that makes off road pipes for stock manifolds so I don't have to cut them out?
Thanks for any help!
Donovan
Donovanl1685 is offline   Reply With Quote
Old 09-03-2013, 02:17 PM   #2
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
Donovan
I can only tell you that if you take off the stock manifold and cats and just put on headers it gets much louder! I think this is the best way to go but I'm biased.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 09-03-2013, 02:19 PM   #3
ZL1-V
Drives: 2013 Camaro ZL1
I have heard the same response from ZL1 owners that have gone that route and love it. I would have done it already on my ZL1 if I was not residing here in California
ZL1-V is offline   Reply With Quote
Old 09-03-2013, 02:31 PM   #4
orangejuice
H1 OFCR
orangejuice's Avatar
Drives: 2013 ZL1 Blue Ray Metallic
That would be obnoxiously loud.
Corsa
Rotofab
BBK
ZL1 Hood/Fascia
AAC Afterburners/Sidemarkers
Havoc Black Chrome
5% Tint/20% Smoked Taillights
orangejuice is offline   Reply With Quote
Old 09-03-2013, 02:46 PM   #5
LuckyZL-1
Ragtop Rocket!!!
LuckyZL-1's Avatar
Drives: Black on Black Convertible
+1
ADM built 2013 Triple Black ZL-1 Convertible M6
ADM custom cam, LPE stage 2 heads with dual valve springs, LS-3 ported throttle body, LPE 2 piece pulley, LPE overdrive balancer, 10% overdrive pulley, ported supercharger inlet, ADM race intake system, stainless works 1-7/8 headers, Injector Dynamics injectors, ADM heat exchanger, ADM dual fuel pump system, ADM exhaust switch, ADM 3 tunes tuning package.
744rwhp 727rwtq
LuckyZL-1 is offline   Reply With Quote
Old 09-03-2013, 03:10 PM   #6
4fbodys
4fbodys's Avatar
Drives: 3 3rd gens 1 4th gen
I have the jba cat less down pipes on my z and love it. I want long tube headers now but it is really loud now the cat do kill a lot of sound you will need a tune to turn off the cel the stock mufflers do a great job of making it quiet on the highway at cruise it's not much louder at all when the valves for the mufflers close sounds very close to the same as stock
2012 ZL1 & my wife
4fbodys is offline   Reply With Quote
Old 09-03-2013, 03:18 PM   #7
Donovanl1685
But it's much louder when it's open? And did you just buy the jba off road pipe god the SS?
Old 09-03-2013, 03:46 PM   #8
4fbodys
4fbodys's Avatar
Much louder when at wide open and louder at idle when cruising on the highway just a little louder not much different than stock. Yes jba off road down pipes http://marylandspeed.com/jba-high-fl...sy-p-2662.html this is the exact pipe from these guys bolted right up less than 45 min
2012 ZL1 & my wife
Old 09-03-2013, 05:24 PM   #9
Donovanl1685
Thank you so much bro, one last question.. With the light on does it cause problem or is it just the annoyance of having the light on?
Old 09-03-2013, 05:44 PM   #10
ZL1_Gary
Drives: Camaro
the light being on will most likely be due to a catalyst efficiency code where it thinks that the cats are not working correctly. It could throw your AFR off a small bit, but overall I would not be worried about a true problem.
ZL1_Gary is offline   Reply With Quote
Old 09-03-2013, 06:28 PM   #11
CanadianZL1#992
ANGRY Z
CanadianZL1#992's Avatar
Drives: 2015 Camaro ZL1
I agree!!!! I've got 1 7/8 kooks and cat deletes, my wife said she can hear me round the corner 4 block from the house. I love it
CanadianZL1#992 is offline   Reply With Quote
Old 09-03-2013, 06:50 PM   #12
Trackman
Trackman's Avatar
Drives: 67RS Camaro ,Black 2013 ZL1
ADM makes an exhaust control to soften the sound/drone of the headers. Worth its' weight in gold if you ask me. You get the best of both worlds.
Trackman is offline   Reply With Quote
Old 09-03-2013, 07:05 PM   #13
CanadianZL1#992
ANGRY Z
If I put that on my personalized plate makes no sense!!!! I'd have to change it to "MUFFLED Z"
By the way Dan I got an award for my car at the super chevy show last Saturday.
Old 09-03-2013, 07:09 PM   #14
4fbodys
4fbodys's Avatar
The cel is for cat efficiency codes checked them with my hand scanner code p0420 and p0430 bank 1 and bank 2 I drove it with a cel for over 5k and raced it at the track with a cel and no real loss of boost with long tube headers if you don't get a tune you will set codes for o2 sensor slow response
2012 ZL1 & my wife
