Old 09-07-2013, 03:11 PM   #1
Rucom197
Mike
Rucom197's Avatar
Drives: 2013 SS M6 Dusk Edition
Installed CAI Intake..Less Responsive! WHY??
I Just installed a Cold Air Induction Intake on my 2011 SS (M6) Camaro. I Checked the MAF and I have a "weak sensor" (Went online and ordered a "strong sensor" should be here in a few days) so maybe this is the problem. I also did some reading up on the forums about the fuse pull. As we speak the fuses are out of the box and I am going to let the car sit for a few hours. Has anyone else had this problem? I could just be losing my mind but for a mod that is said to give some RWHP I felt nothing!
Thanks everyone!
PS: I have had the car for almost 10 days now and I am OBSESSED!
2013 Dusk Edition SS M6 1/205
2011 SS M6 503RWHP-Sold
Rucom197 is offline   Reply With Quote
Old 09-07-2013, 03:13 PM   #2
SSCam77
Drives: 427
Did you do any tuning after the intake install?
check out @LSX_CANADA on Instagram.
SSCam77 is offline   Reply With Quote
Old 09-07-2013, 03:22 PM   #3
Rucom197
Mike
Rucom197's Avatar
No tuning. As of right now the only thing that is on this car is the Cat-Back system that came with the car and the Intake that I just installed. The Vmax throttle body is on back order and the air scoop and bottle relocate should be here any day. So it's not like this car is getting to much air, unless the weak MAF really does make a difference.
Old 09-07-2013, 03:27 PM   #4
rozay
rozay's Avatar
Drives: camaro 2LS LFX A6
do the fuse pull
Niche 20x10.5, BMR 1.25 springs, GFX splitter,1LE Diffuser w/ 3.5 quad tips
rozay is offline   Reply With Quote
Old 09-07-2013, 03:29 PM   #5
DARK AGE 53
DARK AGE 53's Avatar
Drives: 2010 SS
Do you find the car less responsive then what you were hoping for, or is less responsive then what it was prior to the install?
POW/MIA - YOU ARE LOST BUT NOT FORGOTTEN IN SOUTHEAST ASIA
DARK AGE 53 is offline   Reply With Quote
Old 09-07-2013, 03:32 PM   #6
Rucom197
Mike
Rucom197's Avatar
Less responsive then before. Last night around midnight it was low 60's here on LI and the car was flying! After installed it today the temp was high 70's so I doubt this is a factor as well. Just trying to think of everything here, hopefully the fuse pull will work. If not I will give this new MAF a try when I get it in a few days.
Old 09-07-2013, 03:35 PM   #7
rozay
rozay's Avatar
most likely itll be a fuse pull or the weak MAF. ur on the right track
Old 09-07-2013, 03:40 PM   #8
DARK AGE 53
Drives: 2010 SS
Go back and double check your install, check all your wires, hose fittings, clamps and look for any air obstruction in the system.
Old 09-07-2013, 03:57 PM   #9
DARK AGE 53
Drives: 2010 SS
You might also want to check your MAF Sensor, it may have become dirty from your hands or oiled from you new filter. To clean your Maf get some CRC MAF Cleaner, if you're unsure how to clean it here's a video that might help
Old 09-07-2013, 06:16 PM   #10
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
How many tanks of 91 or 93 have you run through it. If your only on your 1st tank you might still have 87 in there. run 2 tanks of 93 to get out all the 87 the dealer put in it. Put your new strong MAF in Then do the fuse pull over night. Check to see if your filter was over oiled if its a oiled filter. Mine was and covered the MAF causing bucking.
JCunningham is offline   Reply With Quote
Old 09-07-2013, 07:09 PM   #11
Danthaman
Drives: 2011 SS/RS
Its you MAF. Weak ones are less responsive. You will notice it more when you add CAI, TB. When you put the new "strong" MAF sensor in should feel a difference in throttle response
Danthaman is offline   Reply With Quote
Old 09-07-2013, 07:16 PM   #12
Danthaman
Drives: 2011 SS/RS
Chase with Apex-Speed had a good forum on this.
Old 09-07-2013, 09:02 PM   #13
DARK AGE 53
Drives: 2010 SS
I don't think a stronger MAF is going to cure his problem, the reason I say that is because he states "Less responsive then before".
Old 09-07-2013, 09:28 PM   #14
cybergrayls3
Drives: 2010 camaro 2ss/rs..m6..CGM
The weak MAF will become more of an issue once modifications are done that increase airflow. He has increased airflow with the CAI. The weak air meter cannot respond/keep up with the additional airflow. Thus the car probably is not adding enough fuel or its slow to do so since the weak MAF is not catching this additional aiflow..this will result in sluggish throttle response, and overall less responsive feeling. The additional airflow these mods create will only improve throttle response and power if the PCM can detect this additional flow so it can change other parameters to match the airflow. If it cant detect this airflow due too a weak/dirty/failing MAF then you are SOL my friend
-Lethal Racing NF cam
-Kooks LT's/high flow cats
-Borla ATAK catback
-CAI cold air intake (black)/Apex scoop
-LSR shifter
-Rick Crawford intake manifold
-Monster level 3 clutch
cybergrayls3 is offline   Reply With Quote
