Old 09-08-2013, 05:39 PM   #1
dimitri
Drives: 06 M5/04 350Z
Interior vents
I hope someone can help
For some reason i get heat when im driving
From the vents even though my dial
Is on the blue dot which i assume
I should not get heat .
The fan is off also
dimitri is offline   Reply With Quote
Old 09-08-2013, 05:52 PM   #2
knowitman
Camaro fan since birth
knowitman's Avatar
Drives: 2013 ZL1
When the fan is off, the right dial is also off. The heat is just natural convection due to it being hot in the engine bay and the air intake catching air due to the car moving.
knowitman is offline   Reply With Quote
Old 09-08-2013, 06:55 PM   #3
dimitri
Ok ..so you feel this is normal.
What is weird is i dont get this from my other cars which get hot also
Old 09-08-2013, 07:46 PM   #4
Evotion
Warehouse 13 Survivor!!!!
Drives: '13 ZL1 - 69' Camaro
It is crazy isn't it?
When I use to drive my 69 year round I never needed the heater during the winter.
Just need to make sure you close them off.
Evotion is offline   Reply With Quote
Old 09-08-2013, 07:57 PM   #5
hawk02
Coupe Newbie
hawk02's Avatar
Drives: '23 CT5-V BW, '21 Corvette HTC
Press the recirculate button with fan off and the heat will stop coming through the vents. You'll have to do this every time you start the car because the setting isn't held across starts.
hawk02 is offline   Reply With Quote
Old 09-08-2013, 08:35 PM   #6
dimitri
Thanks i will try this
